Camber adjustment
The amount of toe in/out really depends on the car being front/rear/all wheel drive. Camber and toe are independent and have zero affect on one another. Regardless of toe in or out, a car that traveling at a constant 65mph (for example) will wear the tires essentially the same amount. Six to one, half a dozen to the other. During take-off from a standing start, yes, having a slight toe in/out (again, depending on the driven wheels) is a good thing.
From my Discount Tire Alignment report, it shows the Factory spec Specifications(Min.-Max.)
Front Camber: -1.1 to 0.4 (Left & Right)
Rear Camber: -1.9 to -0.4 (Left & Right)
Front Toe: -0.05 to 0.20 (Left & Right)
Rear Toe: 0.05 to 0.35 (Left & Right)
And my front camber came out -1.2 (L&R) but toe they adjusted to 0.05, and my rear camber is -1.8L and -2.0R, rear toe is 0.25L and 0.20R within their factory spec, so they did not do anything on rear toe. Should I have them adjust the rear toe to negative since I have -1.8 & -2.0 rear camber? just wanna slow down the speed of tire wear
I wonder how many 3GS have camber at the max or just over the max specs. If this is the case the next question is does the mileage of the car have anything to do with this max camber? What I mean is the older the springs get the more they settle over time and would this not add camber?
Are these specs in degrees?
To is the relation of the front of the wheel to the rear of the wheel. Basically the direction the wheels are pointing. | | would be perfect. / \ would be toe in. \ / would be toe out.
Adjusting one or the other (Camber or Toe) should be independent of one another. Now that's not saying that some manufacturers would not create an adjustment mechanism that'll adjust both at once. Not very common but I'm sure it's out there. Of all the alignments I've personally done myself (hundreds), I've never seen this. At least not on any Toyotas or Hondas that I've laid my greasy fingers on.
I know what camber and toe is. I do my own alignment (until recently).
Adjusting camber changes toe slightly. It may not be of large magnitude but it's there. It's even mentioned in the Lexus service manual. There is a reason why camber is adjusted before toe because when you do toe first and then camber, your toe will be off again. It's the nature of geometry.
Adjusting camber changes toe slightly. It may not be of large magnitude but it's there. It's even mentioned in the Lexus service manual. There is a reason why camber is adjusted before toe because when you do toe first and then camber, your toe will be off again. It's the nature of geometry.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Has anyone tried slotting the holes in the front upper strut tower where it bolts up? This would allow the upper part of the strut to move out so you would have less neg camber.
Not true at all. That only works on cars with McPherson strut type suspension where the strut is actually mounted to the knuckles and no upper control arm exists. This is not the case with our cars. We have upper control arms and the strut is not connected to the knuckles.
interesting I have a 06 gs300 awd, when i went to try on some rims I had I noticed that the inner part of my tire was more worn than the outside of the tire, so could it be I may need new struts up front I just bought it used, with 55k on it
dave197878
04-03-09 07:15 PM
