Suspension Springs, shocks, coilovers, sways, braces, etc.
Need Advice: Tein S Tech Springs + Vossen Concave CV1's
Old 04-26-10 | 06:15 PM
Lex Luga's Avatar
Lex Luga
Default Need Advice: Tein S Tech Springs + Vossen Concave CV1's
So i'm about to buy some CV1's
Wheel specs: 20x9+38 and 20x10.5+42.
Tires recommended 245-30-20(F) and 285-25-20(R)
Problem is that I will be on Tein S-tech springs as soon as this dude can get some free time to install em for dirt cheap.
Problem: Rear Fender will prolly be rubbing.
Questions: How much fender work will I need to do? Can I do this fender work myself? How much will this fender work cost?
Old 04-26-10 | 06:29 PM
RastaRacer's Avatar
RastaRacer
i dont think you will need to roll the fenders at all, im on tein s-techs with vossen and no rub. i would probably considering using 275 rear tire though.
Old 04-26-10 | 06:33 PM
Lex Luga's Avatar
Lex Luga
yeh? 20x10.5 (R)?
Old 04-26-10 | 06:34 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
what brand / model tires you got? good reference point.
problem with 275 is it's harder to find 275/25, and it's a bit shorter than 245/30 since OP has awd (better to keep front/rear close to each other). i wonder if there are 235/30/20 and 275/25/20 tire combo
Old 04-26-10 | 06:40 PM
Lex Luga's Avatar
Lex Luga
Rasta racer u got any pix i could see?
difference is u being in FL prolly have RWD. I got AWD. So you might be lower? im guessing since awd sits higher.
Old 04-26-10 | 07:18 PM
ek9vboi's Avatar
ek9vboi
You didn't get the news Henry? Nitto Invos now come in 275/25!!! But what I'm doing will need a smaller tire. lol
Oh yeah Nitto Invos do come both in 235/30 and 275/25 now. Opened a new door for everyone who wants tires that are to spec.
To OP, I would run that combo if you have the money. No one with Nitto Invos have complained or from what I've read online. The CV1s that were on my car has 245/30 and 285/25 tires, had some rubbing but keep in mind I shaved the rears and am prolly a lot lower then what you will be on springs. A slight shave in the rear should fix your problem. Might want to run a spacer in the front as well.
Old 04-26-10 | 07:27 PM
Lex Luga's Avatar
Lex Luga
Run which combo? the Nitto Invos? 235/30 275/25?
I dont think i could afford them cuz i still need $ to buy TPMS which i hear will be about 200 for a set..
my costs totals would be vossen cv1's/tires/tpms..I'm not tryna spend more than 800-900 on top of wheels
PS where can i find these 235/30 275/25 tire combo? I see tire rack.com doesn't even sell 275/25
Old 04-26-10 | 08:13 PM
jtrue28's Avatar
jtrue28
245/30/20 and 295/25/20 are the exact same diameter...and will keep you at spec...25.8"
Old 04-26-10 | 08:15 PM
Lex Luga's Avatar
Lex Luga
20x10.5 (rear) + 295/25/20...I think that would cause rubbing on a 06 GS awd lowered on tein s-techs
My goal is to be lowered on Tein S tech springs, have the Vossen Concave CV1's on, have no rubbing, while not forgetting about safety, and getting tires + tpms that will be under $1000
So any more suggestions?
Old 04-26-10 | 08:32 PM
RastaRacer's Avatar
RastaRacer
im using falkens 235/30 front, and 275/30 rear
Attached Thumbnails Need Advice: Tein S Tech Springs + Vossen Concave CV1's-021.jpg   Need Advice: Tein S Tech Springs + Vossen Concave CV1's-022.jpg
Old 04-26-10 | 08:39 PM
Lex Luga's Avatar
Lex Luga
looks good..looks like no rubbing at all
u got RWD?
Old 04-26-10 | 11:10 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
wow sweet, so nitto has 230/30 and 275/25? that's awesome!!!
absolutely can NOT run this setup. front and rear different overall diameter. it will throw off the awd system, not good
Old 04-26-10 | 11:23 PM
Lex Luga's Avatar
Lex Luga
note taken
Old 04-27-10 | 01:37 AM
ek9vboi's Avatar
ek9vboi
Hit up the vendor "MC3 Wheels" He is the one that told me about the new tire size that Nitto recently came out with. For sure he can get them for you, just drop him a PM or call him.
www.mc3enterprises.com
Just think of it as a one time fee. Do it right the first time around, not the second. Look on eBay for sensors, sometimes you can find them for 100/set used.
Yup, I'm really thinking hard about going that way or not. I'm on 235/30 and 275/30... it looks like crap due to the "lift" the rear tires give off. Not to mention the sidewalls are completely different.
Old 04-27-10 | 10:40 AM
Lex Luga's Avatar
Lex Luga
Thanks everyone for the input. Pulled the trigger and went with 245/30/20 285/25/20 to go with the concaves.. Will most likely just do some fender work. Hopefully all it will be is taking that black cosmetic strip off!
special thanks to Rominl for everything! He's the man!
update: prolly wont need to do fender work, but i'm already thinkn of goin lower (coilovers in future?!?) then having to do fender work
Quick Reply: Need Advice: Tein S Tech Springs + Vossen Concave CV1's
