New member with some questions about the suspension
Hi,
I have ’09 GS450h, recently I have installed NF210 on my car.
And I notice the front driver side is lower then the other side, is it normal?
The car is brand new never been in accident.
I planning to change to TEIN CST, do you thing I should fix the driver side to have a same height with passanger side?
If I make the driver side same as passenger side, is there any effect on anything (driving, alignment, etc)?
Thanks for the input.
I had the same issue with my NF210's and GF210's on my old G35 and with my Tein H tech springs on my GS. I went with the Tein CST because of this but have never had sagging with the springs with the coilovers.
The issue with this sagging will affect the appearance and will also create pulling to one side or a steering wheels that doesn't seem perfectly aligned. In the end the coilover route really is the best because you are custom height adjustable, the springs are designed to work with the shocks ( as opposed to aftermarket springs on factory shocks), and you have the option to get the EDFC and have the suspension set up be more adjustable than the factory ride setting options
Looks solid man. Very very nice. The stance is clean but on the conservative side. I say take advantage of the easy adjustability of the coilovers and have some fun with it. Take it in and have them bring it all the way down. The car will look insane and still ride relatively well. I had by ride adjusted a dozen times. Its usually about a 45 minute job for the tech at my local shop. Because the rear tires are a little fatter on the sidewall profile I say tuck the rear and make it flush in the front. Either way you got a beautiful ride with some beautiful wheels and you have that nice dropped look. I say burn a few sets of tires and then raise it back up. You will love the way it looks. You also have the option to play with the suspension stiffness . I tend to prefer the suspension to be at a harder setting in the rear. This gives the car better corner exit feel( for a 2 ton lexus) and prevents the rear from dropping to much with bumps in the road.
and its rub too much on the back, even I shave the rear and put it on hardest. Now I can put to all the way soft. I still got some light rub on deep bump.
blackOBS
Suspension and Brakes
01-02-16 01:40 PM
txguy977
07-28-10 11:33 AM
