Suspension Springs, shocks, coilovers, sways, braces, etc.
Adjusting Tein CST coilovers ?
Old 05-17-10, 06:39 AM
SNiiP3R
SNiiP3R's Avatar
Default Adjusting Tein CST coilovers ?
Sorry, tried searching but could not find any older threads.....
I know there are two nuts/rings below the spring. What I dont know is the direction where I need to turn them to lower the height of the car. Is it up or down ? Thanks
Edit:
Sorry, I keep forgeting that we have a sep. section for these questions, mods please move this thread. Thanks again!!
Old 05-17-10, 06:48 AM
LiCelsior
Retired
LiCelsior's Avatar
on my megans, turning clockwise lowers it.
Old 05-17-10, 07:12 AM
TWong350
TWong350's Avatar
Really depends on which way you look at them. If you look at them from the top down (from the upper seat), then it's clockwise. If you look at them from the bottom up, then it's counter-clockwise.
An easy way to look at it is with them while already installed in the car and the wheel off, is to turn the seat to the left.
Old 05-17-10, 07:25 AM
IXI187IXI
IXI187IXI's Avatar
dont touch that upper spring seat that is touching the bottom spring. thats for your preload. adjust the lower ring to loosen the spring seats, then adjust the very bottom ring (just above the strut) to adjust the height, then you can tighten up the lower ring to the upper spring seat ring.
Old 05-17-10, 07:27 AM
Spyder78
Spyder78's Avatar
Teins have no preload adjustment like ur BCs.
valgs350
Suspension
06-20-08 11:57 AM
ULTiMaX99
Suspension and Brakes
12
08-25-07 02:46 PM
GS300Rich
07-07-03 03:29 AM
retrodrive
20
06-12-02 08:19 AM
Quick Reply: Adjusting Tein CST coilovers ?
