Suspension Springs, shocks, coilovers, sways, braces, etc.
Bumpstops...CUT? or NOT?
Old 05-21-10, 10:05 AM
msgs350
msgs350's Avatar
Question Bumpstops...CUT? or NOT?
Hey guys..can you give me some input and maybe some pics. I'm going to lower my 350 AWD on DF210s. The instructions say to cut the bump stops 15-25mm. What have you guys done or suggest? i don't want to be slammed..but lower than nf210. Does the bump stop affect ride quality/bounce? Thanks!!!
Old 05-21-10, 10:19 AM
IXI187IXI
IXI187IXI's Avatar
yes they should be cut. when you lower a car with springs, you are shortening the travel of the strut. theres less room for the strut to compress when you hit a bump. without cutting the bump stop it gives you even less room.
Old 05-21-10, 01:23 PM
TWong350
TWong350's Avatar
Very true and that's the reason why they recommend cutting them. But, I elected not to cut them and hit the bumpstop if I hit a large bump so that I can protect my stock shocks. These stock shots are meant to compress that much. It was my way of protecting them.
Now on my coilovers, I did cut them.
Just my $.02.
Old 05-21-10, 06:03 PM
msgs350
msgs350's Avatar
Originally Posted by Turbo_LX
Your suspension would be sitting on the bumpstop making it for harsh ride... And the fact that the spring won't fully lower to the factory specification.
Are you referring to cutting or not cutting? I'm so confused....
Old 05-24-10, 06:38 AM
IXI187IXI
IXI187IXI's Avatar
if you dont cut them
Old 05-24-10, 07:57 AM
TWong350
TWong350's Avatar
Negative. The car only hits the bump stops at full compression. Not cutting them will cause your car to hit the bump stops earlier due to less travel but will save your shocks.
Old 05-24-10, 08:24 AM
IXI187IXI
IXI187IXI's Avatar
it all depends. cutting them wont hurt the struts. the only thing that will hurt them is if you hit a big enough bump and the strut bottoms out.
Old 05-28-10, 04:57 AM
msgs350
msgs350's Avatar
Default Thanks!
I ended up cutting them.....and sad to say (also weird) my AWD vibrates at stops!
Old 06-23-10, 07:15 PM
SRGS300
SRGS300's Avatar
I did not cut mine and i am with the DF's.. ride is as good as stock. no problems and no harsh ride
Old 06-24-10, 10:38 PM
msgs350
msgs350's Avatar
Do you have RWD or AWD? Mine is a bit bouncy.
Old 06-25-10, 04:43 AM
SRGS300
SRGS300's Avatar
RWD and no bounce at all
steveski
05-27-17 02:41 PM
ZaxF
Suspension
10-05-14 05:42 PM
redrocks
GX - 1st Gen (2003-2009)
18
12-08-11 07:11 PM
sincityIS
Suspension and Brakes
17
07-25-07 08:35 PM
Luxor
02-12-07 07:58 PM
Quick Reply: Bumpstops...CUT? or NOT?
