Tanabe springs labeled?
I received my car back from the shop today and the rear is sitting lower than the front.
Could the shop have put the wrong springs on the rear and the front?
It is possible since the labeling on the springs is not very good and the instruction don't specify which goes on the front or rear. I had to call Tanabe to confirm and what they told me is this. There should be a number on the spring that will end with NR (rear) or NF (front). You should be able to locate this without taking it back to the shop or taking your tires off (or you can take the tire off for ease if you want).
I installed mine with the help of a mechanic friend and we noticed that the OEM spring was taller in the front then the rear so logic would tell you that the taller tanabe spring should go in the front and they might have used that login when installing yours but that logic didn't compute with me since the tanabe springs were supposed to lower the front more than the rear so I put the shorter spring in the front and was correct. Good luck.
executive matchup
ghd8989, your stance with tanabe nf210 springs should look similar to mine (i assume you install NF210s and not DF210s?):
![](http://i47.tinypic.com/24cbqu0.jpg)
![](http://i47.tinypic.com/2yl8ktw.jpg)
if your GS450h doesn't look like mine, then you may have a problem.
Ok. They say R in the rear so maybe they settled and the fronts haven't. Hmmmm. There is not wheel gap at all though and I will have to grind down the fenders before I can even drive it again. So weird. My camber is also at -3 in the rear. Is that normal? I am running a 285/25 in the rear.
Well give it some time to settle and then you should see the front drop. Post some pic of your ride tomorrow.
