I know nothing about air suspension, so excuse my ignorance. I have AWD on NFs and can't stand the wobble...If I was to go air in the future, do you think I would have the same issue? I know guys that have installed F-Sport springs are having the same issue.
from what i know theres very few awd guys runnin air and the ones that are say they dont have any wobbles. keep in mind going air is not a simple swap unless you go with air runner i believe. if you go uas then you need your rear struts modified
air runner is expensive. the kit alone is 4500 which is why people go with uas which is approx 1/2 the cost. install is simple, you can do it yourself.
if you want to wait, im working with PPE on resolving the awd problem.
wobbles usually mean low pressure in the bag creating a soft bag right? and if they are T'ed off they will cause pressure to bounce from left to right to left. .. to right
I would go air runner for sure if I was going to do air, but there are other adjustible suspenisons out there beside air you can go with a compnay called http://www.Hydroholics.net/. They have done some New Gen IS lexus and ride realy good talk to Aaron he is the man in charge and will make sure any question you he can answer. check out some videos I have posted herehttp://www.youtube.com/watch?v=QrW9vOerhXo http://www.youtube.com/watch?v=QrW9vOerhXo
As the video and pictures will show what I'm talking about. I also have had several hydro set up and can tell you if done right there ar not like or mess to clean. These are set up that they have doen for myself over the years they do know what they are doing.
how much is air 3-5k for a good set up a hydro set is 2k for the best set up around plus you have to worry about a huge tank and compressors burning up along with the annoying humming noise.
the noise isnt that loud especially if its in the trunk its barely noticable. the only downfall to hydros for me is if you spring a leak, you got oil all over the place and whatever size tank you have for air, the batteries and accumulators make up for.
