S-Tein or NF tanabe??
CLs
i want tp lower my GS AWD,
i visited Tein website and Tanabe
Tein S.tech has got spring ration::
4.1kg/mm FRONT and 5kg/mm REAR
drop is 1.4inch FRONT and 1.1Rear
the NF210 tanabe::
4.6kg/mm FRONT and 5.8REAR
drop is 1.3FRONT and 0.9Rear
All of these spec is for the RWD not for AWD
what do you advice me? and who tried the S-tein and what do you think of them??
the NF210 tanabe::
executive matchup
if you do a search here, there are reports of vibration problems with springs. some have reported no vibrations however. unfortunately the AWD platform is not good for lowering due to this reason. you can try and hope that you are one of the lucky few that won't experience vibration issues. good luck.
I got s tech teins on my AWD 06 gs...I have the vibration on the front passenger side when my car is in idle, when it is cold outside. With my stock 17's I have a minor wobble from 15-35 mph, but its hardly noticeable from any1 that rides in my car. When i got my 20's its the same wobble and vibrations but stronger and more noticeable. I also have some vibrations at high speeds like around 65+ with the 20's but Ive been told by my friend who is a mechanic that it might be because my lug nuts arent centered and basically i need to get tuner lug nuts.
IMHO i think the s tech teins arent low enough. NF210s will even be higher up than the s techs. SO if you are really set on going with either of those two I would go s tech's.
Im planning to get BC racing coilovers with 8k and 6k spring ratings....Ive heard good things about ride quality with that set up....
executive matchup
if you are looking to get coilovers in order to go lower, that's fine. but if i recall correctly, there were some AWD guys that still got vibration issues after installing bc coilovers. so if you are thinking/hoping that bc coilovers will not give you vibrations anymore, don't have your hopes up.
So im assuming that the vibrations won't be that much worse. Although i know about the rule: the lower you go, the more vibrations you may have. If it happens, it happens. Im loving that slammed or that semi-slammed/sitting right on top of the wheel look.
do you have any idea about it??
