Active Suspension System
executive matchup
but if you are talking about "sport" button, then you are talking about AVS (adaptive variable suspension), which is not the same thing as apsss.
apsss is electronic sways, which is better than f-sport sways. AVS has to do with the shocks, and controls the suspension damping.
regardless of whether you have apsss or not, you can add either lowering springs or coilovers to provide better handling and control.
springs/coilovers with apsss > stock with apsss
springs/coilovers without apsss > stock without apsss
note that with coilovers, you will lose AVS functionality (because you are replacing stock shocks with aftermarket ones).
these abriviations seems to confuse me sometimes... but I think Storm's post above is clear.
The active power stabilizer suspension system (APSSS, or sometimes ****) is the motor located in the spare tire well, rare and available on some 450h and 460s (someone correct me if am wrong).
The adaptive variable suspension (AVS) is less rare, available on all (right?) 450h and 3G V8s, and is indicated by the Sport/Norm switch in the center console, right below the heat/vent seat controls.
Active Power Stabilizer Suspension System (2007 GS430 and above)
Working in conjunction with sensors and acomputer that detect the amount of force needed to help keep the vehicle flat in a turn, the active stabilizer system increases sway resistance by twisting the stabilizer bars. Which pre-loads them to help them behave like thicker sway bars without having to compromise a smooth ride.
Adaptive Variable Suspension (AVS)
AVS is a computer-controlled system that continuously adjusts shock-absorber damping rates to help provide appropriate ride comfort and handling precision. Sensors monitor wheel speed, engine rpm, steering-wheel movement, brake application and vertical body motion to determine the ideal damping rate for each shock absorber. The driver can also select the ride firmness with the press of a button.
THANKS GUYS!!!
Just drove a (modded) GS460 for the first time, and I gotta say....LOVE LOVE LOVE that car. Def worth upgrading from my 2GS 430, even. I didn't think it would be THAAAT noticeable, but that engine..wow! Sounded so mean...
Can you keep the APSSS functional even if you install Strut Bags ? Anybody have a Bagged or GS460, that's SLAMMED on Coilovers with the APSSS?
THANKS GUYS!!!
THANKS GUYS!!!
Typical prices shown are around NZD$14000 (or USD$10000).
