Airrunner with 20"?
What is the most aggressive offset+width for 20" wheel with stretched tyres you can run on a GS with airrunner and rolled/shaved fender without pull? I plan to get Megan Adjustable Rear Lower Camber Arm's and Megan Adjustable Rear Toe Arm's for slight negative camber
I would like to achieve this kind of look:
![](http://i42.tinypic.com/fmm7n7.jpg)
I am shaved flat on the inside and shaved and rolled on the front I can t go any more aggressive without hitting my fenders in the rear at 20x 10.5 +26.5 (I had a spacer milled 2.5 mm to achieve) it would be super close at +26 and my fronts are a 9+12 I would go 9.5 +18 if you want the rim to just tuck.(enabling you to still ride super low cause you won t tear up the fenders) if you just want the fenders to sit in the groove bettween the rim and tire I would go 15mm more aggressive than these specs. Btw i have a 225/30 in the front on a 9 if you go with the 9.5 I'd go 235/30 and the rear 245/30-20. Trust me I have played with this thing for along time to get as low and aggressive on coils as possible and still drive the damn thing. None of my fenders were pulled and I personally want to keep the shape of my fenders factory! Good luck!
If your not trying to pull your fenders and still drive low i wouldn't t go more aggressive. Just cause you have air doesn t mean thd wheel isn t going to camber in any differently than mine does when I compress my suspension with a jack. Most of those super poked out looks are acheived with fender pulling and riding high enough to not tear up the fenders. It's your car bro just giving you some insight
Also if 19" with aggressive offset doesn't rub, does it mean 20" with the same offset won't rub too? I love the look of CL member kenstylegs car but i wish to go 20" instead of 19"
Kenstyle has his fenders pulled also. The specs I gave you will allow you ride low without pulling fenders. My rear toe is within spec I don t see why you would need added arms for more toe and more camber is going to eat tires up faster especially if they re stretched. When I compress my suspension with another Jack under my wheel my rear tucks by 1-2 mm it's super close. The front is perfectly flush at my ride height but will tuck by slightly more not all to different than the first pic you posted. If the rim is poked out to far and you ride low when you hit a bump your going to tear up the fender and rim. Like I said you can definitely go more aggressive but you ll have to get into pulling fenders and running ridiculous amounts of camber. It's all relative!
I thought kenstyle only rolled his fender?
This is a quote from 3GS wheel thread.
[QUOTE=kenstylegs;5201020]
when i use to have megan coilover with 3 in drop. i have no issue with rubbing fender. just simply use the fender roller to roll. but now with air runner, i have rise a little higher than before, cuz it's not stiff as coil spring.
i don't rise to stock height unless is my girlfriend or my mom wants to drive my gs.
Also the white 2GS owner says he only rolled his fender but running -4 camber on all 4 wheels. I'm planning to go the same route as him for a better VIP look.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
How about if with -4 camber angle for rear wheel? Does it mean i can go a little bit more aggressive as i like the look of some negative camber at the back. Quicker tyre wear and camber wear are alright for me.
I'm running -3.5 in the rear with factory arms and .13• of toe. The toe is within factory specs of .04-.20 in the front I'm running -3• of camber all factory. These camber measurements are at ride height I'm sure if you bag it and drop it while slammed you will obviously have more - camber. But anyway like I said when I compress my back wheel it tucks and look almost identical to how the white gs looks
