Suspension Springs, shocks, coilovers, sways, braces, etc.
any body make a camber kit for our gs350.
Old 06-21-11, 02:54 PM
tungo
tungo's Avatar
It fits then. Will call tomorrow and inquire about the SPC kit. Jasgs350, would you happen to have the part number for the SPC front ball joint?
Old 06-21-11, 03:01 PM
Kcook700
Kcook700's Avatar
Check it.. there isn't much difference between the two suspensions..
Old 06-21-11, 05:56 PM
JasGS350
JasGS350's Avatar
Here you go;
00+ LEXUS IS300 SPC FRONT ADJUSTABLE CAMBER KIT Part #67525
You will have to shave the upper control arm so you can adjust the camber. It's really easy. Search the forums for this kit installed. There are detailed pictures from an install on a IS250.
Old 06-21-11, 06:13 PM
lkapimp216
lkapimp216's Avatar
Im running -3.5 camber int he rear with the toe set within factory specs and I have gotten about 7-8k per side on my rear tires. I also drive my car like it is stolen and take turns hard on a regular basis. I have Vredestine tires that i have flipped and even tho they are inside outside tires there is no road noise produced by flipping them and the ride is just as good as it was right side out. just my .02 BTW I am also stretched with a 245/30 on a 10.5
Old 06-21-11, 06:40 PM
Lex Luga
Lex Luga's Avatar
I have all 4 Megan rear Megan arms made for the IS250/350 on my AWD GS350 and they work just fine.
I need a camber kit for the front, but have no idea if the SPC ball joint for the IS300 will fit for the AWD GS350. The ball joint has to be pressed into the upper control arm. Can anybody confirm?
I just got the 2 Megan camber n 2 Megan toe arms..will install within the next few weeks
Old 11-07-11, 08:17 PM
Lex Luga
Lex Luga's Avatar
Ran into the 2nd gen IS forum and saw this...SPC has new ball joints made for the ISx50's.. As far as I know we (3gs guys) have the same suspension as ISx50 guys. Well here is where i saw it from:
https://www.clublexus.com/forums/is-...amber-kit.html
Here is a link of the new ball joints on the SPC site:
http://www.spcalignment.com/componen...AFrom&to=USATo
Here is the cheapest price for a pair of these new ball joints:
http://www.iapdirect.com/product.php?productid=43478
Old 11-07-11, 09:37 PM
sagikun
sagikun's Avatar
you don't rub like crazy? I still can't fix the fender liner rub no matter how much I heat and shape them. only way is to remove them but then it looks like crap and added road noise
Old 11-08-11, 05:31 AM
passnu2
passnu2's Avatar
guess that big red search button is broken again...
The 2gen ISx50 shares the same exact parts I posted this over a year ago.
megan now says they cary four our car since my discovery & research on their website. They did NOT test them on our car
I sent Figs my OEM suspension parts so he cold r&d for us. I suggest to get his parts and do it right
Old 11-08-11, 08:31 AM
Lex Luga
Lex Luga's Avatar
Had no clue since it was never brought up in 3gs section. I just ran across this thread when i pressed "get new" on mobile CL.. So ur saying just wait for figs specific front ball joint camber correction thingy?
Old 11-08-11, 09:30 AM
socal3gs
socal3gs's Avatar
without buying all these parts or mod the suspensions, could a good alignment shop put my gs350 back in factory specs with 1'' dropped all around? Please let me know, Thx
Old 11-08-11, 10:07 AM
passnu2
passnu2's Avatar
yes I think he may already have them in production. He is a vendor on the boards. Its not like the SPC that is posted or being talked about. Its the entire upper arm that is replaced. No adding of extra parts this way its done the right way
your still in factory spec so you only need an alignment
Old 11-08-11, 02:58 PM
Lex Luga
Lex Luga's Avatar
I Def gotta pm him then.. Good lookin out!
Old 11-08-11, 06:02 PM
JasGS350
JasGS350's Avatar
Figs products are top notch! I have had zero issues with my Figs Mega Arms and toe links. Also, the IS300 SPC Ball joint kit works just fine on a 3gs, haven't had an issue with it yet and my car is a daily driver.
Old 11-08-11, 07:02 PM
Stormforge
executive matchup
Stormforge's Avatar
figs really need to advertise their products here more on the 3GS forum. while i do know about them, it sometimes easy to forget about their products as they don't come to mind.
Old 11-08-11, 08:52 PM
passnu2
passnu2's Avatar
I dont think they are allowed to? pretty sure they need to stay in the vendor section.
Quick Reply: any body make a camber kit for our gs350.
