AWD Wobble/Vibration Solution - Testers Needed
#167
So I am in the market for the BC Racing coils for my '07 AWD IS250 and after reading this thread and three others I am trying to make sure I get the most out of my setup. So far what I hear is that axle spacers and possibly RCA blocks help to prevent the wobble/shake at low speeds?
Can anyone who has done this testify to them working??? I am wondering if anyone has both coils and RCA blocks and if it solved your issue. Thanks guys!!
#169
![](http://i255.photobucket.com/albums/hh144/Phantom-V/Mobile%20Uploads/IMG_7691156719714.jpeg)
so far he doesn't have any complaints.
#171
so the blocks help keep the level of the axles the same. cool
Its either this or RCA blocks. I saw some people lowered with RCA had complaints but i guess it also depends on how low you plan on going. I just want mine with at least just a finger gap or less. i hope that doesn't cause to much vibrations with RCA blocks or if i go the plate route.
#172
some people have done both, springs and rca blocks
heres some more info on the rca blocks with awd
https://www.clublexus.com/forums/sus...my-awd-gs.html
#173
Good day IXI187IXI my name is thusanth i have been following up your threads and honestly it is very helpful. I got my megans installed on my 08 gs350 awd and man the vibration is a killer i would like to confirm if i install the RCA would the vibration go away?
#175
I am getting these spacers made up, they will be done by end of the week, my question is once these spacers are placed on the axles of a lowered car, would it need a new alignment? Wouldn't it change the camber a bit?
#176
[QUOTE=IXI187IXI;8158943]if your referring to me then yes my car was awd. no need to make them if its rwd ![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
my spacers took care of my issues and i was tucking all my tires
I lowed mine with the 11mm axle spacers and still had wobble with about 1 1/2 fender gap. So what i did I made my own motor mount spacers at half inch now I'm tucking 18s
![](https://i80.photobucket.com/albums/j175/lxl187lxl/59372860.jpg)
