Suspension Springs, shocks, coilovers, sways, braces, etc.
AWD Wobble/Vibration Solution - Testers Needed
Old 08-10-11, 09:25 PM
mikegs2006
Registered User
mikegs2006's Avatar
but where do these rings go?
Old 08-11-11, 02:04 PM
leonsup
leonsup's Avatar
Originally Posted by IXI187IXI
hey sorry i havent responded in a while guys. im actually in the process of selling my car so sometime this week i'll just post specs of the spacers for everyone. you can have them machined at a local shop (should cost more than $70, at least thats what ive paid for a few sets) and if you need any additional info on installing them, feel free to post or pm me.
Wow, why you selling? I sold my '07 about a month ago and bought an A6.
Old 08-12-11, 04:19 AM
IXI187IXI
IXI187IXI's Avatar
the rings go on the end of the axle. when the axle is pulled out, you slide the spacer on. the OD of the spacer is the same OD as the end of the axle so all you need to do is line it up and temp. hold it in place till you slide the axle back in and tighten the axle nut.
Old 08-25-11, 06:09 AM
imadesign
imadesign's Avatar
i machined the two rings according to IXI187IXI spec.
i will have them installed after two weeks since im still in duty, will take pix, record a video and post it.
scores goes to IXI187IXI if this fixes the vibration
Old 08-25-11, 06:54 AM
IXI187IXI
IXI187IXI's Avatar
it doesnt get rid of them 100% but it does drastically cut them down by nearly 80-85% imo. again this vibration is all subjective to the person which is why i was going to have people test them out prior to have them produced.
Old 08-25-11, 07:27 AM
imadesign
imadesign's Avatar
IXI187IXI can you please mark where they sit exactly.
thanx alot
Attached Thumbnails AWD Wobble/Vibration Solution - Testers Needed-untitled.jpg
Old 08-25-11, 09:52 AM
IXI187IXI
IXI187IXI's Avatar
wrong figure, it sits on the part that is behind all of that. figure 43-02
Old 08-25-11, 11:11 AM
imadesign
imadesign's Avatar
this figure>
Old 08-25-11, 11:15 AM
IXI187IXI
IXI187IXI's Avatar
goes where the arrow is
File Type: pdf
Old 08-25-11, 11:52 AM
imadesign
imadesign's Avatar
ok i got it now. appreciated
Old 08-27-11, 10:56 AM
jmoc1
jmoc1's Avatar
Hey, notice your close to philly... Have any idea where can i get these spacers thinking about getting Bc coilovers and want to get everything done and install once Thanks
Old 08-31-11, 08:05 AM
passnu2
passnu2's Avatar
Im shocked that people are not jumping all over this???
Old 08-31-11, 08:33 AM
IXI187IXI
IXI187IXI's Avatar
your telling me. people complain about the problem but then when i solution is given no one cares
Old 09-04-11, 06:15 PM
HMFIC
HMFIC's Avatar
Man i've been looking all over and trying to follow these threads! FINALLY i've found this one!.
I have a turbocharged S2000's and lowered. axle spacers are very common for our s2000's. They are called half shaft spacers or full. The half shaft spacers are the most popular as we can just unbolt the axles from the diff portion, slide them out just enough and put the spacers on, rebolt and done.
I very much believe these are a great solution.
Do you have these premade i can purchase?
Allan
Old 09-05-11, 03:07 AM
jre002
jre002's Avatar
You can blame that on the 4GS.
Quick Reply: AWD Wobble/Vibration Solution - Testers Needed
