lowering spring suggestions
Looked at it today, looks like if I take about a qtr inch off the lip it should fix the problem.
strange...your offset is same as mine, you should have no problems with rubbing (i have no rubbing issues at all with the same offsets).
edit: well my front is 20x8.5, and rear is 20x10. so your wheel size is 0.50" wider than mine for both front and rear. that could be a factor, but not 100% sure.
