suggestions 06 gs430
hi guys,
I have an 06 gs430 with 20" tsw snettertons, they are staggered, believe its 20x8.5 on front and 20x9.5 on rear.....I want to know which springs you'd recommend, I want to keep the AVS feature so i can change between sport and normal mode... I was told i basically just need to change the springs if i want to keep this feature
2 questions i have,
Fsport springs are not compatible with my car because I have AVS right?
also, between the DF210 and the NF210, which springs would you guys recommend?
2 questions i have,
weird cuz if you look here:
http://lexus.sewellparts.com/accesso...2006/2957.html
it says does not apply to vehicles with AVS
okay so i guess im mistaken, how do i know if my car is equipped with optional AVS?
if its not, which of the 3 types of springs would you say are the best for look and comfort
fsport
nf210
or df210
fsport
nf210
or df210
okay so does anyone have a 3gs with the SPORT / NORM/COMFORT switch and have aftermarket springs installed?
If so, which ones did you go with? Im looking for not too much drop but just a little stiffer ride as this thing drives like a tank and is too bouncy
NF210, DF210, or FSPORT?????
Yes I did this on my GS and it will work. Rominl is correct that its the shocks and has nothing to do with the springs. I had DF210 springs but any spring will work with this set up! If I may suggest that you just get coils I think you will be happier with them on this car. I wish I had made this move first but I wanted to keep that avs function and it was just "ok"....
got that so far?
while looking into fsport springs, i was on lexus sewell, it says on there that the springs are not compatible with cars equipped with AVS http://www.lexus.com.bh/technology_e....asp?model=All
i want to know if anyone with a similar vehicle to mine (3gs RWD with AVS) has installed fsport springs on their vehicles, or will it not work
i also want to know which springs are recommended for a stiffer ride, but not too much of a drop
