Camber kit gs350?
only camber kit i found for this car is the rear camber kit by megans? is there a kit for the front?
http://www.circuitmotorsports.net/cambergs350.html
which ones do i need to buy to fix my camber the link on top has 4 different ones? camber arms, traction arms, upper arms, and toe arms
any help would be nice thanks
I got the SPC front ball joint a couple months ago if you are looking for positive camber in the front. The factory upper control arm would have to shaved a bit for it to fit. There are several threads about it. I also have the SAGE front RCA's because I'm on coilovers. FIGS also make rear control arms for our cars.
00+ LEXUS IS300 SPC FRONT ADJUSTABLE CAMBER KIT Part #67525
You can get the control arms and toe links from Figs, http://www.figsengineering.com/suspension.htm
CL vendor.
I got the front ball joint kit from CircuitMS, www.circuitmotorsports.net
CL vendor as well.
CL vendor.
CL vendor as well.
Here you go the thread below should should help you out. Its from an IS350 but it applies to the 3GEN GS as well.
SPC Front camber + Megan rear suspension rods install photos + results
https://www.clublexus.com/forums/sus...s-results.html
thanks for the answers guys im new with all this camber, lowered my car now i wanna save my tires.. what are the other megan products used for in the link (traction arm), (upper arms) (toe arms). im purchasing the camber arms from megans. how much did you guys get your camber kit installed for?.. FIGS control arms link doesnt work..
For the front camber kit, I went with 00+ LEXUS IS300 SPC FRONT ADJUSTABLE CAMBER KIT Part #67525
For the rear I got the Figs FIGS MEGA Arms GEN2 IS/ GEN3 GS ENTRY ECONOMY VERSION
Price: $545.00
Model: GEN2ISMEGA
Manufacturer: FIGS Engineering
For the toe links I got FIGS TOE Links Gen2 IS/ Gen3 GS IS-F ISX50 GS350 GS460
Price: $170.00
Model: GI23TOEV1
All these products are top notch and very easy to install. You will have to grind down the front control arms so you have the ability to adjust the front camber. Very easy to do. My tire wear is perfect!
