more questions on awd vibrations
I have a awd gs lowerd down to one finger gap. And im aware of the vibrations when stoped and the wobbles from 0-10 mph but some times I get vibrations when im driving and some times I dont. but my question is are those vibrations caused from being lowerd? This all started when I went lower. thanks for any answers.
sounds expensive..Correct me if i am wrong, but isn't one known problem with lowering cars is that down the road, the axles will fail? Right now my axles are already starting to slighty spew out some oil.
no more than you would usually pay for an OEM axle, someone said 1600+ for 2 axles..... that's insane, the shop quoted me a long time ago around 800 to do my miata's rear axle, custom tailored too, and able to handle approximately 600HP+ (maybe 400lbs of TQ?).
Like I said in the other post, if anyone is AWD, lowered, and in the orlando area, it could be awesome to help a lot of members on here out and possibly solve your axle dilemma
As for you Lex Luga, axles spewing out oil sounds like a problem outside of it failing, seems like in the process of lowering your vehicle, you ripped the axle rubber covering. That is easily fixable and you'll be saving yourself from a future 1600+ axle job =]. Your axle TRULY fails when it starts clicking when you turn
executive matchup
didn't one of our members come up with a solution to the awd drive problem? let me see if i can find it...
edit: ok, found the link, but it was not a complete fix, just a reduction in the vibration. still better than nothing i guess....
https://www.clublexus.com/forums/sus...rs-needed.html
As for you Lex Luga, axles spewing out oil sounds like a problem outside of it failing, seems like in the process of lowering your vehicle, you ripped the axle rubber covering. That is easily fixable and you'll be saving yourself from a future 1600+ axle job =]. Your axle TRULY fails when it starts clicking when you turn ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
50 bucks sounds too cheap for this job. Changing the boot is actually slightly more work than replacing the entire axle.
