DIY: Lowering your GS
Really appreciate for the diagram but really don't know which number to look for, I mean for a torque specs and all the red squared out are all the components that needed to be taken out and torque to spec for replacing coilovers?
Couple of follow up points on Mike's DIY thread as I just finished doing this.
1) You MUST disconnect the upper control arm b/c there is not enough room to move the bottom of the shock out of the way. The tapping method does work and it did pop out just fine after a few love taps
2) You either need to disconnect the sway bar or do both sides of the front (or rear) at the same time. I did the driver side first and when I tried to do the passenger side, the new "position" of the coilovers put a lot of tension on the sways that didn't give me any play at all when I disconnected the passenger side shock. I had to unbolt the bottom of the coils on the driver side and then there was enough play.
Edwin
Edwin
On the 3rd gen you will need to remove. Even when at the dealer when I first installed springs we had to reeve it. Save yourself the headache and just remove. It's rather easy. No special tool and tap it on both sides with a mallet. You can remove the upper A arm if you want, I tried both ways, and this is much easier.
Alright... I'm installing the coil overs and the ball joint won't seperate from the spindle. I've used a mallet and a sizeable hammer hitting up on the upper arm and it won't budge. I used WD-40 to attempt to free it up but, no luck. I'm guessing my only other option is to use a ball joint seperator to push the ball joint bolt up through the upper arm.
Any other suggestions?
Todd
