lowering awd
I have 07 gs350 awd with vossen 20" wheel without any suspension
now im having a problem with rear side of my car it make rubbing if someone seat back there..
so if i install lowering spring
it may fix that problem ?
What offset are the wheels? Lowering will make the rubbing worse. Your problem is your tire size.
Not only they're >3% larger in diameter than your stock. They're also ~1% difference from each other(front/back). Getting the diameter as close as possible in AWD is important.
I advise you change the tires and use this calculator to select a better size.
http://www.1010tires.com/TireSizeCal...mp;vehicle=yes
