Hey I plan on lowering the car with some coils and run some 19s. Thinking approximately 2 inches or so. Will I need a rear toe kit and/or camber kit? What about front? Thanks
probably not. when you get an alignment they should be able to set the toe pretty close to stock so you wont have to worry about wearing your tires out.
did you have your car aligned? i had mine dropped well over 2 inches and with a proper alignment, i didnt have any camber wear.
Unfortunately I did not have mine aligned yet (b/c mine isn't dropped that low) but a friend of mine that is dropped around 2" went to an alignment shop and they said that there are no camber (only toe) adjustments on his GS. He drove on it anyway and ate through his tires in about 3 months.
