Suspension Springs, shocks, coilovers, sways, braces, etc.
Help with lowering my 2006 gs300 awd Please help!!!
Old 07-05-12, 02:39 PM
sklexus
sklexus's Avatar
Default Help with lowering my 2006 gs300 awd Please help!!!
right now my front suspension is around a inch or so higher than my back ones i was wondering if i just want to balance the look should i just change the springs or what should i do ? If just get the springs which ones to get and what do i need to know. please help and thanks
Old 07-05-12, 04:16 PM
mr nut
mr nut's Avatar
You can look into an RCA (roll center adjuster) kit...a 25mm kit will lower the car 25mm in the front. (about 1 inch)
Old 07-05-12, 05:35 PM
msgs350
msgs350's Avatar
If you lower the car, it will vibrate. Unless you don't want to deal with that issue. Try what MrNut suggest and do the RCA blocks to even it out.
Old 07-06-12, 10:13 AM
sklexus
sklexus's Avatar
so what do i need to buy and how much does it usually run. Also i will it take the comfort away. do they have like an inch and a half?
Old 07-06-12, 10:18 AM
PeteinPA
PeteinPA's Avatar
Go to the 3rd Gen classifieds. You will see them advertised by PHML. I bought mine from him, they are a simple install so you can DIY. What size wheels do you have? If you have 17's you can only intall the 20mm, if 18's you can use the 25mm.
Old 07-06-12, 11:24 AM
sklexus
sklexus's Avatar
the thing is summer time is 18" and winter time is 17". So i guess i can only do 20 mm then?
Old 07-06-12, 11:30 AM
PeteinPA
PeteinPA's Avatar
Yes, you will need to go with the 20mm.
Old 07-09-12, 06:54 AM
sklexus
sklexus's Avatar
thank for all the input
Old 07-09-12, 07:47 AM
IXI187IXI
IXI187IXI's Avatar
Heres the install thread
darren14
Suspension
06-13-14 07:36 AM
dnam85
Suspension
06-02-14 10:42 PM
Whartmann
Suspension
05-29-14 07:45 AM
frenchie66
07-23-08 02:37 PM
Rexus300
04-20-08 08:16 PM
Quick Reply: Help with lowering my 2006 gs300 awd Please help!!!
