I heard some AWD vibrates (even slighty) even when not lowered. The minimal springs produced are 1inch or slightly under and people report vibrations with those installed. not sure if there are any options for lowering without the vibrations.
I put the 20mm RCAs on my AWD GS and the only vibrations that I've been able to notice are when the car is at high idle (warm-up sequence), then put in gear, and foot on the brake completely stopped. Once the engine has reached temperature, there is absolutely NO vibration at stop.
To me, this seems like a very viable option for AWD guys that want to get rid of the reverse rake gap.
For winter, I plan on putting the stock wheels/tires back on and possibly removing the RCAs if we get enough snow to warrant the increase in ground clearance. It is SO easy to install/remove the RCAs, a cave man could do it!
The RCAs with the F Sport sway bars have been a great combination for me.
I have heard about this issue too, but I am on air and I havent gotten any vibrations at any height yet. Is this something that happens over time or right off the bat?
mine was tucking tire on 20 vossen and it vibed bad. so does air solve it?
As much as I would like to think so.....I really doubt it. There was a member on here from Canada that had the white AWD on air and he said his vibrated as well.
