Does coilover height affect ride
Does coilover height affect ride quality? I've heard on the BCR's it doesn't but then I've heard the opposite, anyone tried different heights and noticed a difference? I'm running BCR's and i'm getting them adjusted today to try and help ride quality. I'm running stock 18's and lowered to no gap and the ride it just too rough (not bumpy) on any damper setting. MIght ask them to reset preload but not sure that will make a difference. thanks for any ideas.
Of course it doesn't - that 3" reduction in suspension travel you've just created has no bearing whatsoever on ride quality.
Lexus were toying with us all along, as it's obviously surplus to requirement!
All facetiousness aside, sit and think for a moment about what you've done - here's a bit of a clue..........reduced travel, and increased spring stiffness.
Now what do YOU think is going to happen when you hit a bump?
At least you're running on 18s, so the tyre will provide some cushioning, but your description of "too rough" does not convey anything of use for us to help you with.
If you use the wrong perches to adjust your ride height you will change your spring rates, impacting the ride quality.
Unless you are corner balancing the car or know what you're doing you can tweak your spring rates to your liking...but it can cause premature strut failure and you could really ruin your ride quality.
just got back and after test driving different ride height, everything from almost slammed to almost stock, the ride quailty didn't really make a huge change. it was slightly, slightly better when the car was lifted, but not enough to justify lifting it. Preload was at 5mm. only problem now is the car still has a slight pull to the right on any road, even after an alignment and new tires. Maybe worn suspension components, anyone had to replace any bushings on the control arms?
With a dual-height adjustable setup like the BC's you won't lose internal shock travel like you will on a single adjustable setup, so that's good.
BUT, when you lower a car you are messing with suspension travel and geometry on the arms/links side of things, and that will affect how the car handles and rides. Raise it up a bit and see how that feels.
If you don't have the swift springs for your BC Racing coilovers, I would look into upgrading the springs to Swift.
Swift springs uses a different material from the Standard BCR Springs, and from doing research online they do offer a smoother ride compared to the standard BC Racing Spring.
i've heard that about the swift springs but wasn't quite sure that the purpose of them was to create a smoother ride, can anyone comment?
Well the alignment was done on a hunter machine and its within spec, still pulls a little, drives me nuts
damon
05-24-17 02:28 PM
