Thinking of lowering with df210
10-08-12, 09:12 AM
Will be running Iforged 20 inch wheels (Dont have offset bought used) .Wheels were on a 2GS and fit flushed. Thinking of running 245/35/20 front and 275/30/20 rear. My question is will I have to do fender mods? Has anyone had problems with them sagging? I was told to use Suspension technics,Tein basics,or KWV1. Has anyone installed any of these on there car? how do does it look? Thanks in advance for your help
10-08-12, 09:39 AM
more than likely will rub when you turn the wheel all the way to the left or right
10-08-12, 09:42 AM
what's the width of front wheels ? u need to know these & offset to figure out it will rub or not.
to be safe, once u go low, it's better to do a little fender mods to avoid any kind of rubs.
10-08-12, 10:56 AM
I've had DFs on my car for over 2 years and i still like them. The drop is pretty low and it does seem to sag a bit in the rear.
Without knowing the exact specs of the rims, i can't comment on the rubbing. Those tire sizes seem like they would rub though.
10-08-12, 10:58 AM
10-08-12, 12:14 PM
how can i find out offset on the wheels? fronts looks like 8.5 and rear 10
10-08-12, 12:20 PM
thats width, not offset.
check on the inside of the wheel and look at the back of the spokes or barrel, it should look something like this if they stamped the wheel
10-19-12, 12:18 PM
Okay went to Iforged and got info on the offset. 20x8.5 +30 20x10 +30 . what do you guys think will i rub
10-19-12, 01:23 PM
with a 245/35 yes it will probably rub on full turns considering the tire is over spec'd
10-19-12, 01:57 PM
The rear will rub also.
I'm lowered on DF210's, 20x10 +35 (265/30-20) with rolled rearmfenders and I rub on dips with only me in the car. With passengers, forget it.
11-20-12, 11:56 AM
lowering with df210
got my springs today. decided on buying 245/30/zr20 for front and 285/25/20 for rear . i believe i will be okay with the size.
02-22-13, 05:11 PM
I got 20's on mine with the df. I can't remember my offsets but it rubs even after rolling the fenders. Looks good but you may have to shave. The only place it seems to rub is where the bumper meets the metal on the fenders both in the front and back.
bg_281
07-17-09 02:02 PM
Gs430Boi
03-11-08 08:52 PM
Felix gs43
05-03-07 06:17 PM
Papos
Wheels, Tires & Brakes Forum
20
11-21-03 04:33 PM
CamRen
01-14-03 09:36 PM
2753020 ,
2gs ,
300 ,
awd ,
back ,
df210 ,
fit ,
gs ,
gs300 ,
gs350 ,
lexus ,
offset ,
ofrim ,
strut ,
wheel
