GS450H drop with RCA block?
Thinking about lower my gs450h with stock wheel and RCA block. Does anybody has the picture with GS450h after lowered with RCA block. If i decide to do this. Should i do both front the rear or just the front. I notice there are 3 different sizes avaialble. 20mm, 25mm, 30mm. I dont want to make it too low but imporve a little handling of GS450h. I prefer to do 20mm or 25mm.
The only reason i want to go RCA block. It is becuase i compare my gs450h with my friend's gs430. both have AVS. but driving quanlity is quite different. i guess height height makes the different. GS430 feels heavier and solid than my GS540h even they have same suspension system. any input is welcome. thanks!!
I had 20mm in the fronts on my car. I noticed a slight improvement in handling, car felt more stable at higher speeds. It eliminated the fender gap in the front and was pretty much even with the back after. I decided to go lower all around with F-sport springs so my RCA blocks are for sale now. PM if you're interested.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
Wald
Don't do it it you have after market wheels, it lowers you car to low and ruins your plastics. Not to mention it makes your car look like your front shocks went out, the back of the car stays too high, the gs450h is a $60k plus car bro Leave it alone unless you have the cash to properly lower it
BiGRiGNiG
Suspension and Brakes
06-09-12 06:06 PM
mikeho
06-18-08 04:52 PM
