Suspension Springs, shocks, coilovers, sways, braces, etc.
my fsport lowered on rsr super down springs
Old 04-22-13, 09:58 AM
djpeakSD
djpeakSD's Avatar
Originally Posted by 4thGNGS350
I ordered the same springs, but I haven't recieved them yet.
Did you experience any head lamp leveling issues?
Have you had the car aligned since installation?
if so, are the front and rear camber results within the Lexus spec tolerance?
If you feel your lights are too low you can adjust them very easily. I did that on mine.
Old 04-22-13, 01:19 PM
sydtoosic
sydtoosic's Avatar
nice... in the 2nd pic, she looks dumped (almost). wheels would definitely complete it.
Old 04-22-13, 04:29 PM
Mi10
Mi10's Avatar
How do you adjust the headlights?
Old 04-23-13, 06:49 PM
golfpunks
golfpunks's Avatar
more pics of the wheel gap and alignment sheet. please give two cents on alignment so i know how off i am. thanks
Old 04-23-13, 08:46 PM
FsportAlex
FsportAlex's Avatar
AWD or RW?
Old 04-23-13, 10:19 PM
terrycs
terrycs's Avatar
The rear is only a little out of spec, but it looks like you'll need an alignment kit unless you do not mind uneven tread wear. Not sure why the front right corner is so out of whack though.
Still kinda hard to tell if the tires are actually under the fender.
Old 04-24-13, 05:08 AM
Outrage
Outrage's Avatar
Why is the camber -0.7 on the driver's side but -2.1 on the passenger's side? I'd expect them to be much closer than that after the spring installation.
As for camber, negative camber up front will increase cornering grip (decrease understeer) but decrease straight line stability. Negative camber in the rear will increase cornering grip (increase understeer) but decrease straight line grip. I think the GS is a fairly neutral-handling car (for something of this weight class) so I wouldn't want to tweak the camber differences front to rear to too great an extent.
Old 04-24-13, 08:14 AM
golfpunks
golfpunks's Avatar
Maybe I should bring it back.. Got the lifetime alignment and its the latest machine..
Old 04-24-13, 09:17 AM
Vossen Wheels
Former Sponsor
Vossen Wheels's Avatar
Looks good sitting lower with the RSR Springs! Can't wait to see what wheels you end up with and any other mods you may have in store!
Old 05-30-14, 07:33 PM
myfly350
myfly350's Avatar
how do i adjust the lights?
Old 06-01-14, 09:51 PM
jdsantos
jdsantos's Avatar
Great looking F Sport. Did you happen to put any wheel spacers on the front or rear?
TriggrHapy
Suspension and Brakes
04-06-11 08:03 PM
JIS
02-05-09 05:30 PM
juice14
07-24-08 07:17 PM
lexboi250
07-21-08 05:41 PM
Quick Reply: my fsport lowered on rsr super down springs
