Anyone attempting to install RS*R springs on your own?
I got my springs delivered, and attempted today to install at least the rear springs. I've done my 2003 G35 sedan and other cars at home before, but the GS350 set up is a whole lot different.
I referenced Sewell's site for drawings, and CL for a great writeup from Edmond's on our suspension, but I still couldn't get a rear spring off without removing anything major (or all of the darn arms), or putting myself or the car at risk of injury. The front's look straight forward, but the rears have me puzzled.
Has anyone installed springs on the GS350 that can provide any tips for safe removal? I won't hesitate to let pros do the job, but I love working on my own cars, so I'd like to at least try this myself at home first (I do have all the right tools).
Thanks for any help!
It's where you can get online manuals for our cars : http://techinfo.toyota.com
Subscriptions can be for only 2 days for $15, or a whole year ($$$). Everything I really needed to know to get started was in the repair manual. Super helpful.
Turns out I was 1 bolt away from getting the rear spring out correctly and safely. Now I have to wait until Thursday, but by the end of the day my RS*R's will be installed. Front's will be quite easy.
It really isn't too bad if you have the right tools and take your time. Reference the attached picture. The rear should be as easy as 1. unbolting the lower shock mount, 2. unbolting the lower sway bar mount, and 3. unbolting the rear lower suspension arm bolt (supported by another floor jack because that's what holds the coil spring). Lowering the jack will release the compression on the spring and it will come right out.
I highly recommend two floor jacks, but one will work too as long as the car is securely supported on jack stands so you can use the floor jack to lift suspension parts for removal/unbolting, etc.
Last edited by jscgs350; 05-02-13 at 02:55 PM. Reason: Corrected to reflect the right bolts to remove.
I plan on creating a short video, and/or pics on Thursday. That's the soonest I'll be able to get to this. Once all done I'll post a thread.
Bolt #3 is a killer...
Ok, well I gave up, and here I sit at the dealership waiting for the install and alignment and posting this via my iPad...
In the picture above, bolt #3 is a lot harder than I ever thought it would be to remove. Instead of doing anything stupid and unsafe, I decided to pay the pros.
I'll post before/after pictures when I get home later today. I got the regular RS*R Down Springs, which drop the car an inch.
Oh well, back to the trial coverage on HLN that everyone else here is glued to watching...there is a gorgeous 2013 LS F-Sport on the lot I get to stare at at least. White, loaded, and around $87k! There are a few GS's too, including 2 F Sports with rear steering.
Does anyone have a PDF of the procedure?
I don't think removing bolt 3 is correct. I would have taken off the outboard bolt on the left of bolt 1 after I raised the arm a little with a floor jack.
Removing bolt 3 seems scary because you can't tell when it is properly "unloaded" by a floor jack.
In any case, please post up pictures after the springs are installed. I'd like to see a good side shot showing what wheel to fender gap is left.
I don't think removing bold 3 is correct. I would have taken off the outboard bolt on the left of bolt 1 after I raised the arm a little with a floor jack.
Last edited by jscgs350; 05-02-13 at 02:58 PM. Reason: Added image andmore comments.
