Suspension
Is it possible to have a bad strut and it not leak....??? I swear something is wrong with it but the dealer says nothing is wrong. At passing speeds on the highway the front end feels like its lifting and drifting to the right. Lexus swears that nothing is wrong. I invited their tech to drive it but we can't seem to get a time nailed down; after all they are about 1 hr from me.
The now has a very unstable feeling during city driving. The car almost feels like it's teetering which led me to believe that a corner is bad. What do y'all think
yes a shock/strut can be blown and not be leaking. a good way to test is to stand outside the car and go to the corner you suspect to be bad. place your hands on the top of the fender and give it a push down. if its pretty stiff and rebounds back without moving around too much, then the shock/strut is probably good.
if your having a drifting feeling, it could be your tires and the wear on the tires or maybe even an alignment.
The dealership told me the same thing and they said the Michelin Pilots A/S 2 tire were directional and that was the issue. Ha!!! I replaced them with A/S 3s, a non directional tire, and there was no big difference.
I need to go test drive another gs to compare. I think they have no clue. I will try your suggestion later. Thanks
It's kinda hard to say with my current situation. They are smooth and quiet.
I had the alignment done and even a bushing replaced. They checked the eps and steering but didn't find anything. I am going to post in the southeast region forum to see if I can a board member who can drive my car to help trouble shoot. I now don't like driving past 90mph. I may just take a day off work and visit Another dealership in south Atlanta.
Going back to the shocks, they can go flat and loose their gas pressure. That usually will cause the shock to spring back too fast cause that will cause you to loose your rebound damping. Go hit a thin speed bump or find a pot hole and hit it with the wheels, not fast, but enough to jar the car some. The one that pops the most will probably be the bad one. Then the bushings also and possible the wheel bearings. Lift the wheels off the ground and try to move the tired from top and bottom, back and forth. There shouldn't be and slack. And the list goes on
mine's were at 50-60k I believe.... replaced under CPO warranty (a week or two before warranty gave out).
After warranty gave out I gave it a month or two and went full air LOL>
