Who used the 2gen IS Megan front upper arm on a 3GS
Since Megan hasn't responded to me e-mails and calls I thought I'd ask on the forum. I see posts everywhere that the 2gen IS and 3gen GS have identical suspension parts yet Vendors are not selling the same camber kits for the front. There were old post that some used the 2gen front camber kit on the 3gen GS but no explanation as to wether they wanted more neg camber or to correct camber. In my case I want to correct camber. I would rather replace the front upper arm than use the SPC ball joint kit since I plan on installing myself. Is there anyone out there who can confirm wether or not it will fit w/o issue to correct camber?
I finally called Megan Racing and got a hold of a guy to cofirm that the front camber arms from a 2gen IS will fit in a 3gen GS since the suspension parts are nearly identical, even though they never actually test fitted on a GS (posts several years ago confirmed but nothing mentioned about correcting camber). He also said it you had aggresive camber (-3 or more) than it probably wouldn't do much good for correction. While Pink is still the only option available currently, he said the blue will be available again in the near future.
