Last edit by: IB Advertising
Browse all: Steering and Suspension
- IS GS: How to Install Lowering Springs
Step by step instructions for do-it-yourself repairs
DIY Guide: 2014 GS350 F-Sport Lowering Spring Install Guide
#31
Not sure if they rent them out but I bought mine for about $15. Like Jeff noted, the susp parts are aluminum...didn't want to risk damaging them.
#32
#33
#34
No need for a control arm puller. All you have to do is tap on the metal that attached to the control arm (the part that runs vertical) with a hammer and the vibration will loosen it. when loosening the bolt, make sure you leave the bolt on with a little thread left so when the control arm is loose, it will catch itself. Then you can loosen the bolt to disconnect the control arm. Easy and less energy at work... Good Luck
#35
Thanks guys... for those that have done this install... What was the most difficult part. I've done a few on basic civics and mustangs but I'm just worried about starting it, hitting a snag and not having a car for a day, haha.
#37
For the fronts, it was definitely compressing the springs so make sure you have good spring compressors, and a good impact wrench. Also, make sure you note the position of the top cap before you remove stock spring. Use the markings on top of tower as a reference to ensure it goes on how it came off else it won't line up w/LCA.
As for the rears, aligning the bolts in the lower control arm was a pain so make sure you have a long screwdriver to help line it up (rubber mallet comes in handy here). Have fun, and look forward to seeing the final results.
#40
#42
Hi Jeff,
Thanks for the DIY post for the lowering of tanabe springs..I have a 2014 gs350 rwd fsport.. What do you thing is a good estimate of hours this job would take by a shop...First wheel shop quoted me 2.5 hours...Second general auto care place looked up lowering springs in the system and had it quoted at 4-5 hours but guy is a friend and will only charge the time it takes...I am also throwing on new 20" wheels at same time...Do the tanabe's need time to settle in or should i have the alignment done right away? both shops weren't ego maniacs atleast and open to me bringing in your DIY guide, knowing more info is always better ...
thanks
Jay
thanks
Jay
#43
Hi Jeff,
thanks
Jay
thanks
Jay
Depends on the shop's confidence. My shop quoted $250 for spring install which equates to 2.5-3 hours if shop rates are ~$100/hr. Drive the car for a week or two to let them springs settle and then get an alignment. Then take pics and share!
#45
It usually takes me about 2-3 hours to do the install with one guy on the job. If I have 2 people on the job and split the work load, then it can be done in about 1-1.5 hours. Just depends on how busy everyone is around the shop.
I'm still doing 2nd Gens. I'm about to break 1000whp on mine through the auto trans. I do a little bit of everything these days lol. I have a GS450H as my daily driver. Looking to pick up a RC-F to do some R&D in the near future.
