Suspension Springs, shocks, coilovers, sways, braces, etc.
SPC Camber Kit
Old 10-30-14, 02:41 PM
  #61
N54MPower
N54MPower's Avatar
Originally Posted by Wht95scort
That black arm is not the toe arm but another upper arm that too needs to be adjustable.
The suspension set up we have is similar to the 350Z and SPC makes both arms separately to offer even more camber adjustment. Ideally you'd like to have both to add a greater range of adjustment but most of the people on here and in general are trying to remove the negative camber added from lowering the car.
These arms aren't for everyone but I still think they provide an answer for most of us that wasn't available.
Old 11-03-14, 01:20 PM
  #62
terrycs
terrycs's Avatar
I have a feeling there might be a run on these since they also work on the IS. So I just placed an order for the kit through LSD Motorsports who is local pick up for me. Turn around time is about 1 week.
They are charging $145. Installation will be $95 if I have them do it.
They also have shipping available.
lsdmotorsports dot com
Old 11-03-14, 09:08 PM
  #63
sam430
sam430's Avatar
I was going to mention it to the 3IS forum too but decided to wait a lil, lol.
Old 11-07-14, 12:06 PM
  #64
mrpartsman
mrpartsman's Avatar
here is a pic of the GS rear camber arms, it will be available by December.
Old 11-07-14, 12:28 PM
  #65
neegroy
neegroy's Avatar
mrpartsman are you at sema?!
Old 11-07-14, 12:42 PM
  #66
mrpartsman
mrpartsman's Avatar
I was just got back yesterday.
Old 11-07-14, 02:16 PM
  #67
sam430
sam430's Avatar
Looks great, hope we get bushing options.
Old 11-08-14, 01:47 PM
  #68
mrpartsman
mrpartsman's Avatar
I don't think there is an option Sam, that is the final piece u see.
Old 11-08-14, 06:42 PM
  #69
sam430
sam430's Avatar
Ahhh, that's fine. Thanks.
Old 11-18-14, 12:28 PM
  #70
jeg650
jeg650's Avatar
Is there a group buy for these?
Old 11-20-14, 11:47 AM
  #71
168Motor
Former Sponsor
168Motor's Avatar
SPC Club Lexus Special
Feel free to PM me for pricing.
Any questions or concerns are always welcome!
Thank you
-Kevin
Old 12-12-14, 04:16 PM
  #72
0mghi2u
0mghi2u's Avatar
Default Question
Is spc going to ever make front camber kit? For the 13 ga
Old 12-17-14, 11:42 AM
  #73
FIGS
The Maker
FIGS's Avatar
We have opened our preorder as well and we will have both upper links with the same options we have on the 3GS which is camber correction or negative camber. The #2 arms will eventually get polyurethane bushings. We should be able to support a wider range of adjustment on this arm in our version.
Thanks Mike
http://shopfigs.com/v1/index.php?rou...product_id=280
3IS 4 GS rear upper links. Camber kit
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 01-08-15, 09:24 PM
  #74
mikec78
mikec78's Avatar
I got the SPC camber kit installed last weekend and I finally got around to getting the alignment.
Here is what I have:
Springs: RSR Down
Wheels: 20" New Gen 3-piece
Camber kit: SPC
Install was done by 168 motoring (thanks to Kevin for a great install) - 168 motoring in Torrance has some top notch people there and if you are in the area and looking for a good shop, this is the place!!!
http://168motoring.com/
Alignment is now corrected:
Old 04-06-15, 11:48 AM
  #75
Kcook700
Kcook700's Avatar
Mike, just to confirm, you only installed the SPC bar correct? I believe the stock adjustable toe bar was sufficient?
Quick Reply: SPC Camber Kit
