Suspension Springs, shocks, coilovers, sways, braces, etc.
SPC Camber Kit
Old 04-06-15, 01:50 PM
  #76
mikec78
mikec78's Avatar
Yes, just the SPC bars
Originally Posted by Kcook700
Mike, just to confirm, you only installed the SPC bar correct? I believe the stock adjustable toe bar was sufficient?
Old 04-14-15, 11:42 AM
  #77
1BAD4DR
1BAD4DR's Avatar
This thread was so helpful. Thanks guys. Ordering rears and fronts should be good!!
Old 04-15-15, 11:08 AM
  #78
DoriSaru15
DoriSaru15's Avatar
I dont think SPC makes front camber arms.
Old 04-16-15, 01:20 AM
  #79
2_xplicite
2_xplicite's Avatar
Finally got a chance to install some Tanabe NF210 springs along with Figs camber kit during Easter. Still awaiting to get an alignment this weekend.
Old 04-16-15, 07:33 PM
  #80
spdrcr771
spdrcr771's Avatar
Ok. So I'm new to the IS-F club & i just bought some BC coilovers today & goin to install them this weekend. So I'm looking for front & Rear camber kits. So even though Figs website says 3IS & 4GS for these rear arms... They fit 08-13 IS-F?
Old 04-17-15, 03:10 PM
  #81
terrycs
terrycs's Avatar
I think the suspension is only shared with the 4GS beginning with the latest model IS? For sure not as old as 2008 because the 4GS isn't that old.
Old 04-18-15, 01:15 AM
  #82
sam430
sam430's Avatar
Is the figs arm heavier than OEM arm? I haven't installed mine yet so I don't know the weight of the OEM arm.
Old 04-18-15, 08:31 PM
  #83
FIGS
The Maker
FIGS's Avatar
The rear suspension is very different than the IS-F.
The link is heavier than OEM because the OEM arm is all aluminum, no adjuster.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
stlgrym3
Suspension and Brakes
03-03-12 03:48 PM
2JZSteven
IS - 1st Gen (2001-2005)
07-16-10 05:22 PM
aznpapaya
21
02-15-10 01:35 AM
Wald GS
Wheels, Tires & Brakes Forum
10-21-03 08:56 PM
kevs
03-02-02 05:15 PM
Quick Reply: SPC Camber Kit
