Suspension Springs, shocks, coilovers, sways, braces, etc.
Headlight adjustment leveling warning
Old 09-18-15, 08:24 PM
sam430
sam430's Avatar
Default Headlight adjustment leveling warning
Just finished installing my j5 coilover for the rear. Recieved a warning to check headlight leveling.
I just finished installing the front. Is there another leveler in the front?
Old 09-19-15, 10:12 AM
djrabbi
djrabbi's Avatar
It is probably cause once you lower, you need to adjust the headlights. Apparently they aren't really "auto" adjust like other makes.
Old 09-19-15, 09:05 PM
sam430
sam430's Avatar
Thanks for the reply. Confirmed the headlight was point up.
Old 09-19-15, 10:12 PM
sam430
sam430's Avatar
There is no sliding adjustments on the 4gs height sensor?
Old 09-21-15, 10:04 PM
sam430
sam430's Avatar
i figured out how to adjust it. Will post later when i get a chance to do it.
Old 09-24-15, 10:13 PM
sam430
sam430's Avatar
Default Rotate this
So you remove 10mm nut by holding the lever towards the rear of the car to keep the nut from rotating. The square shape of the lever fits the sensor.
Once the nut is removed and you pull away the lever from the sensor, you will see the square shape, rotate 180 clockwise, (keep a note of what you did, you might want adjust again like I did and forgot).
Notice the square shape.
Shervin350
11-21-20 10:36 AM
simonsez
05-17-20 09:03 PM
GS4_Fiend
07-18-09 11:35 AM
vindedreal
GS - 1st Gen (1993-1997)
08-30-08 10:05 AM
flm
03-13-02 09:33 PM
Quick Reply: Headlight adjustment leveling warning
