Suspension Springs, shocks, coilovers, sways, braces, etc.
Suspension Torque specs
Old 07-09-16, 06:52 PM
R6_Dude
R6_Dude's Avatar
Default Suspension Torque specs
Can anyone give me the info? About to do an install, searched (here and google) and check owners manual, but got nothing. 2016 gs fsport.
Old 08-09-16, 02:54 PM
mrkwinning
mrkwinning's Avatar
I am interested in this info as well.
Old 08-09-16, 10:13 PM
kamskeez
kamskeez's Avatar
Same! Dropping my 2014 F Sport next week. Would love to get the necessary torque specs.
Old 08-11-16, 12:30 PM
Nixus
Nixus's Avatar
1. INSTALL FRONT SHOCK ABSORBER ASSEMBLY
  1. Install the front coil spring insulator lower to the front shock absorber so that both of the recessed parts are aligned.
    Text in Illustration *aRecessed Part
  1. Using SST, compress the front coil spring.SST09727-30021 (09727-00010, 09727-00021, 09727-00031) NOTICEo not use an impact wrench. It will damage the SST. HINT:The front coil spring can also be installed/removed using the hydraulic spring compressor.
  1. Install the front coil spring so that the end comes to the stepped portion of the spring lower seat.
    Text in Illustration *1Spring Lower Seat
  1. Install the front spring bumper on the front suspension support sub-assembly.
    Text in Illustration *1Bolt*2Front Suspension Support Sub-assembly*3Front Spring Bumper*4Front Coil Spring Upper Insulator*5Cutout
  1. Align the bolt of the front suspension support sub-assembly and the cutout of the front coil spring insulator upper, and install the front coil spring insulator upper on the front suspension support sub-assembly.
  1. Align the width across flat of the piston rod end and front suspension support sub-assembly to install the front shock absorber.
  1. Temporarily tighten a new lock nut to the front shock absorber.
  1. Adjust the front suspension support sub-assembly so that the bolts come to the positions as shown in the illustration, and remove the SST from the front coil spring.Text in Illustration *aOutside of the Vehicle[img]file:///D:/LEXUS/Manual/rm2010e/repair2/img/v100136.png[/img]Front of the VehicleNOTICE:
    1. Do not use an impact wrench.
    2. Make sure that the width across flat on the piston rod end is located parallel to the shock absorber bush.
    3. Make sure of the direction of the front suspension support sub-assembly when removing the SST.
2. TEMPORARILY TIGHTEN FRONT SHOCK ABSORBER WITH COIL SPRING
  1. Install the front shock absorber with front coil spring on the vehicle by tightening the 3 nuts on the suspension support side.Torque: 67 N*m{ 683 kgf*cm , 49 ft.*lbf **
  1. Insert the bolt from the rear of the vehicle, and install the front shock absorber lower side on the front suspension lower arm.
  1. Temporarily tighten the nut while holding the bolt.
  1. Tighten a new lock nut.Torque: 28 N*m{ 286 kgf*cm , 21 ft.*lbf **
3. INSTALL ABSORBER CONTROL ACTUATOR (w/ AVS)
  1. Check that the control rod of the front shock absorber is in the position shown in the illustration.Text in Illustration *a40°NOTICE:If the control rod is not in the position shown in the illustration, turn the control rod to adjust the position before installing the absorber control actuator.
  1. Install the absorber control actuator to the actuator support bracket.
    Text in Illustration *A2WD*BAWD*a40°--
  1. Turn the actuator clockwise 40° until a click is felt.NOTICE:
    1. Before turning the actuator, make sure to check that the actuator output shaft and control rod are securely connected.
    2. Do not turn the actuator more than 40°.
    3. Do not drop the absorber control actuator. If it is dropped, replace it with a new one.
4. INSTALL UPPER SHOCK ABSORBER CAP (w/ AVS)
  1. Connect the connector.
  1. Install the upper shock absorber cap with the 3 nuts.Torque: 20 N*m{ 200 kgf*cm , 14 ft.*lbf **
5. CONNECT FRONT SUSPENSION UPPER ARM ASSEMBLY
  1. Install the steering knuckle to the front suspension upper arm, and tighten it with the castle nut.Torque: 87 N*m{ 887 kgf*cm , 64 ft.*lbf **
  1. Install a new clip to the steering knuckle.NOTICE:Further tighten the nut up to 60° if the holes for the cotter pin are not aligned.
6. CONNECT SKID CONTROL SENSOR WIRE
  1. Install the skid control sensor to the front shock absorber with coil spring with the bolt.Torque: 6.0 N*m{ 61 kgf*cm , 53 in.*lbf ** NOTICE:
    1. Do not twist the skid control sensor while installing.
    2. Be careful not to deform the bracket of the front shock absorber with coil spring when installing the bolt.
7. STABILIZE SUSPENSION
  1. Install the front wheels.Torque: 103 N*m{ 1050 kgf*cm , 76 ft.*lbf **
  1. Lower the vehicle and bounce it up and down several times to stabilize the front suspension.
  1. Remove the front wheels.
  1. Jack up the front suspension lower arm placing a wooden block in between. Apply a load to the front suspension so that the front suspension lower arm is placed in a horizontal position.
8. FULLY TIGHTEN FRONT SHOCK ABSORBER WITH COIL SPRING
  1. Fully tighten the bolt on the lower side of the front shock absorber while holding the nut.Torque: 108 N*m{ 1101 kgf*cm , 80 ft.*lbf **
9. INSTALL FRONT WHEELTorque: 103 N*m{ 1050 kgf*cm , 76 ft.*lbf **
10. INSPECT AND ADJUST FRONT WHEEL ALIGNMENT
Measured (07-31-22)
Old 08-11-16, 12:34 PM
Nixus
Nixus's Avatar
1. INSTALL REAR NO. 1 SPRING BUMPER
  1. Install the rear No. 1 spring bumper to the rear shock absorber assembly.
2. INSTALL REAR SUSPENSION SUPPORT ASSEMBLY
  1. w/o AVS:
    1. Install the rear suspension support assembly, rear No. 1 shock absorber cushion and rear No. 1 shock absorber cushion washer to the rear shock absorber assembly.
    2. Align the rear suspension support assembly so that the studs are positioned as shown in the illustration.
      Text in Illustration *aAbsorber Lower Bush Axis Line*bRear Suspension Support Assembly Stud (Toward Vehicle Interior) 2-Point Axis Line Front of the Vehicle
    3. Using a 6 mm hexagon wrench, hold the piston rod of the rear shock absorber and tighten a new nut.Torque: 18 N*m{ 184 kgf*cm , 13 ft.*lbf ** NOTICE:Make sure that the socket hexagon wrench is fully inserted.
  1. w/ AVS:
    1. Install the rear suspension support assembly, rear No. 1 shock absorber cushion, rear No. 1 shock absorber cushion washer and actuator support bracket to the rear shock absorber assembly.
    3. Hold the actuator support bracket and tighten a new nut.Torque: 18 N*m{ 184 kgf*cm , 13 ft.*lbf ** NOTICE:Hold the actuator support bracket so as not to deform it.
3. TEMPORARILY TIGHTEN REAR SHOCK ABSORBER ASSEMBLY
  1. Install the 3 nuts to the upper side of the rear shock absorber.Torque: 74 N*m{ 755 kgf*cm , 55 ft.*lbf **
  1. Temporarily install the rear shock absorber assembly to the rear No. 2 suspension arm with the bolt and nut.NOTICE:Insert the bolt with the threaded end facing the rear of the vehicle.
4. INSTALL ABSORBER CONTROL ACTUATOR
  1. Check that the control rod of the rear shock absorber is in the position shown in the illustration.Text in Illustration *a40°NOTICE:If the control rod is not in the position shown in the illustration, turn the control rod to adjust the position before installing the absorber control actuator.
  1. Turn the actuator clockwise approximately 40° until a click is felt.Text in Illustration *a40°NOTICE:
5. CONNECT TOE CONTROL LINK SUB-ASSEMBLY (w/o DYNAMIC REAR STEERING)
  1. Connect the toe control link sub-assembly to the rear axle assembly with a new nut.Torque: 70 N*m{ 714 kgf*cm , 52 ft.*lbf **
6. CONNECT REAR STEERING LINK ASSEMBLY (w/ DYNAMIC REAR STEERING)
  1. Connect the rear steering link assembly to the rear axle assembly with a new nut.Torque: 70 N*m{ 714 kgf*cm , 52 ft.*lbf **
  1.
    1. When jacking up the rear No. 2 suspension arm assembly, be sure to jack it up slowly.
    2. Do not jack up the rear No. 2 suspension arm assembly too high as the vehicle may fall.
    3. Make sure to perform this operation with the vehicle kept as low as possible.Jack up the rear No. 2 suspension arm assembly, and place a wooden block underneath to avoid damage. Apply load to the suspension so that the rear No. 2 suspension arm assembly is positioned as shown in the illustration.Standard Length (A):9.7 mm (0.3819 in.) Text in Illustration *1Wooden Block*2JackNOTICE:
8. TIGHTEN REAR SHOCK ABSORBER ASSEMBLY
  1. Tighten the bolt of the rear shock absorber.Torque: 110 N*m{ 1122 kgf*cm , 81 ft.*lbf ** NOTICE:Since a stopper nut is used, tighten the bolt.
9. INSTALL REAR SUSPENSION ARM COVER
  1. Install the rear suspension arm cover to the rear No. 2 suspension arm with the 3 bolts.Torque: 12 N*m{ 122 kgf*cm , 9.0 ft.*lbf **
10. INSTALL REAR WHEELTorque: 103 N*m{ 1050 kgf*cm , 76 ft.*lbf **
11. INSTALL INNER LUGGAGE COMPARTMENT TRIM COVER
12. INSPECT AND ADJUST REAR WHEEL ALIGNMENT
Measured (07-30-22)
Old 08-11-16, 12:37 PM
Nixus
Nixus's Avatar
A quick copy paste from the service manual, ignore the image links as they are links from my local HDD and for some reason I can't edit those out.
Old 08-12-16, 09:36 AM
mrkwinning
mrkwinning's Avatar
It is very hard to know which is which without pics. Are there pics in the manual?
Old 08-12-16, 10:07 AM
Nixus
Nixus's Avatar
Pics are in the manual. I'll make some screenshots if it makes things a little bit easier to understand
Old 08-17-16, 10:04 PM
Nixus
Nixus's Avatar
Put everything in a word file for you guys to download
http://s000.tinyupload.com/?file_id=89038296255728446804
puffdaddy (06-19-17)
Old 08-17-16, 11:05 PM
kamskeez
kamskeez's Avatar
You the man! Thanks!!
Old 04-03-19, 11:25 AM
dTxworld
dTxworld's Avatar
Tried downloading the file but it's since been removed. Anybody here have a copy/link/way to access that file to view the pictures? Thanks in advance.
Old 06-08-19, 11:33 PM
wenesak
wenesak's Avatar
same here ,Tried downloading the file but it's since been removed. Anybody here have a copy/link.
Old 06-10-19, 08:21 AM
dTxworld
dTxworld's Avatar
I ended up going to this Toyota website and paid 20 bucks for 3 days of unlimited access to their car manual documentation online. Can't remember the site but just google it and then enter your car model and it has everything you need
asiandavid
Suspension and Brakes
04-04-16 01:23 PM
tenaciousF
06-14-10 08:29 AM
jaredc
07-18-08 03:55 PM
nardeezy
02-09-06 02:07 AM
Quick Reply: Suspension Torque specs
