Torque specs for front Upper Control Arm (UCA)
I had to take off the upper control arm when I messed up the ball joint threading on my coilover install. Now, I can't find the torque specs for the 2 bolts that hold the UCA. All I see is the specs for the 3rd gen which are 39 ft-lbs for the UCA bolts and 64 ft-lbs for the castle nut that holds the upper ball joint. Please help me out if you've come across the specs. Thank you!
