GS450H lowered on RSR down
Finally got the car lowered on RSR downs and had SPC camber arms installed. Shout out to Josh at Meraki Autoworks for great deals on the parts and Jonathan at Jovenal Autoworks in San Diego for great customer service and professional install services.
Sucks not having anyone to have gone down this road on a Hybrid 4GS so everything I’ve done so far is trial and error. My only concern is having 400 extra pounds of Hybrid battery, I sit lower in the rear than all the other cars I saw on here with RSR downs. Granted this suspension is specifically for the Hybrid GS450H. My front sits perfect if you look at the pics but the rear has the look of the RSR Super downs. Rear needs to be raised about 1/4”-1/2” max. Tried to get an alignment but rear is tucked about 1/4". Don't wanna get thinner tires because the ride is perfect. Rolling fenders would have to be an absolute last resort.
Trying to source out coil spring spacers. The ride is almost stock! Drove 2 hours to San Diego to have the install done because I trust Jovenal Autoworks and they have proven themselves on Luxury cars and the 4GS time and time again. The drive back was so very comfortable and similar to stock. Only time you can really tell it was slightly stiffer was driving on I-5 with the occasional "Dukes of Hazard" bumps they have. No rubbing at all.
Any help with finding 1/4" coil spacers would be great! Preferably rubber over aluminum. Below I'm Posting some before and after.
Stock front
Stock left
Springs and arms
Lowered front
Lowered left side
Lowered right side
Jovenal contact info
Stock front
Stock left
Springs and arms
Lowered front
Lowered left side
Lowered right side
The rears do look lower as you had indicated. Once you load up a passenger or two in the rear, it will be more noticeable. What about getting custom coilovers for the car instead? Using springs made for the GS350 is iffy.... although it fits, it was not designed for a car that's 400-lbs heavier in the rear. 400-lbs is a lot of weight.
These Springs are for the GS450H
Thank you good sir!!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Thanks bro! I need to check out a few pics of wrapped roofs to see how it will look. but if it fits, ill definitely go down that road. those rear side spats are nice! I need to find those! thanks again man!
02REX (12-17-18)
although most aftermarket coilovers do have adjustable damping, it just not accessible from the driver's seat (each corner would have a **** that you physically have to turn to adjust, which is less convenient).
aftermarket coilovers use their own shocks which are not compatible with the stepper motors that sit on top of the factory shocks to adjust the valving/damping as you choose between normal/sport/sport plus.
dTxworld (12-18-18)
I appreciate the advice as I'm going through the process of deciding to go with coils/arms or springs as many of us have probably thought of at one point... I've had both coils and springs on my other vehicle, a 2010 Accord, and remember that I was actually good with the Eibach springs I had on it temporarily but eventually moved to Megan coils+camber kit in the long run bc I was eating through expensive 19" tires (and found a good deal in the group). I'm assuming the springs plus a kit/arms would fix that issue someone please correct me if I'm wrong.
That being said, is there any other advice you veterans have for choosing one over the other and/or feedback regarding the 2 options? Thanks in advance Lexus fam!
O2REX, how are you getting on with the springs? I've got a 4th gen GS450h in the UK and am looking for new springs to reduce the body roll.
Are the RSR Down, the same as RSR Down Sus?
From the website it looks like the spring spec for the GS350 is the same as the spec for the GS450h, which might explain why its a bit lower at the rear than wanted. Sounds like the springs are suited to the GS450h, but RSR haven't made them any different to the ones for the GS350.
importhope
18
03-05-14 02:12 PM
