Gs350 way too high please help
10th Gear
Gents
Really need help!!!
Did suspension repairs on my 2013 gs350 L RWD.
control arms, ball joints, stabilisers and shocks.
all parts original and supplied by the dealer.
upon completion car was lowered from the lift and my ground clearance now at abt 250 mm.
car is way too high.
took it to dealer.
all parts installed correctly.
springs never changed.
no one knows what to do.
own my own garage.
please help!!!
18s
Really need help!!!
took it to dealer.
own my own garage.
please help!!!
18s
Did you work on both sides at the same time? Is there a chance that you installed a LH part on the Right and a RH part on the Left?
Were the suspension parts tightened before the car was on the ground loaded on its own weight?
10th Gear
Rear and front is up now.
all parts are in right places - confirmed today having exact same car standing on the other lift at the dealer.
suspension was tighten up but we’ve loosen bolts after we had that idea to see if it won’t drop, it didn’t.
what is really strange is that we tried to put old shocks back and the car is still up.
thats what is very very confusing to me.
10th Gear
All parts are original (only difference is that new shocks are not gas and oil but just gas) those discontinued. But as I mentioned old shocks were installed and still no difference.
parts (L + R) have not been installed mistakenly and everything in its own place.
10th Gear
Only think I can think of is springs
while waiting for last part springs were loose on the ground
but I’ve never experienced that spring can expand with no pressure to it
Have you tired loosening everything that was changed/replaced or messed with and then lowering the car so it is on its own weight to see if that allows the car to seek normal height?
Is it possible to tighten the inner pivot bolt on the control arm so tight that the weight of the car wouldn't be able to make it move?
