Suspension Springs, shocks, coilovers, sways, braces, etc.
Sway bar
Old 01-19-22 | 09:25 AM
TurnerS's Avatar
TurnerS
Default Sway bar
Hi I was talking with a buddy and we were talking about possibly installing a sway bar for tighter steering on my 2013 GS 350 I know they offered an upgraded F sport one for the IS but am unsure if they do for the 4GS. Does anyone know if it is even worth it to replace or upgrade the sway bar or if Lexus offers an oem upgraded one? Thanks.
Old 10-16-23 | 01:50 AM
peteharvey's Avatar
peteharvey
For the GS RWD, the 2016 model year got a thicker front roll bar with the part number ending in 30840.
In the 2018 model year, the GS RWD got a thicker rear roll bar with the part number ending in 30571.
How do I know the new front roll bar was actually a few millimeters thicker?
Because it did not fit on the older brackets!
Old 10-21-23 | 09:09 AM
4GS350's Avatar
4GS350
Does a thicker anti rollbar gives tighter steering feel? I know i can feel the same after changing to the GSF front LCA bush....
Old 10-23-23 | 09:01 PM
repugnante's Avatar
repugnante
It is more beneficial for cornering than tighter steering.
Most tend to get the GSF front lower control arm bushings. I opted for the RR Racing poly bushings and that significantly improved the steering feel and tightness. You feel it even more when in S+ mode. Just gotta lube them up every so often but they are far different than the GSF rubber bushings. And correct me if I'm wrong but I believe the F Sport got thicker sway bars front and rear compared to the base trim models.
Old 02-08-24 | 02:08 PM
SBPhoto's Avatar
SBPhoto
I have the super pro rear bar installed on the stiffer setting and its great. It doesnt directly effect the steering, it helps the rear end rotate so that when youre exiting a corner the rear comes around really easily (cuts out understeer feeling). it also helps keep the weight of the car from feeling like its gonna push you to the outside of a turn, you can really wrap the car through turns with an "on rails" feeling. Theres an overall sharpness added to the car when changing directions and less body roll.
Papakit
05-12-17 02:56 PM
xknowonex
Suspension and Brakes
55
07-08-08 05:30 PM
George Hsieh
11-08-02 06:12 PM
