Struts covered under extended warranty?
2019 UX200
10 year 100,000 miles Lexus Factory Extra Care platinum Zero Deductible Warranty
Are struts covered under the above warranty? Is "strut rod" another name for a strut?
From the warranty paperwork:
SUSPENSION (Front and Rear): Bushings/Bearings; Control Arm Shafts; Electronic Suspension Actuator/Motor and Compressor; Front and Rear Coil Springs; Front and Rear Stabilizer Bar; Front Leading Arm; Front Spring Assembly; Radius Arm; Spindle; Spindle Support; Steering Knuckle; Strut Rod; Suspension Spring Shackles; Sway Bar Link; Torsion Bar Spring; Upper and Lower Ball Joints; Upper and Lower Control Arms; Upper Arm Shaft
