🐜 Apple CarPlay Bug 📞
When connected to Apple CarPlay (via USB/Lightning cable) and when I'm speaking with someone on the phone, the person on the other end hears me very faintly. I can hear them perfectly.
It doesn't matter if I initiated the call or if it was an incoming call, the remote person can barely hear me.
In the rare event that everything does work, it will only work once. Any subsequent phone conversations revert back to the original issue.
Also, disconnecting the cable (which disables CarPlay) temporarily resolves the issue, but that defeats the whole purpose of CarPlay.
My iPhone 11 Pro Max is up-to-date with the latest iOS (v13.3).
As per other internet website suggestions, I have tried all of the following—but none have worked:
Who else is experiencing this?
- Toggle the “Audio” icon when the phone is in the process of calling. (this did not fix the issue)
- Tried different cables, including the Apple OEM cable. (this did not fix the issue)
- Turned Bluetooth off—although Lexus Enform will disconnect BT when CarPlay is connected via cable. (this did not fix the issue)
I have it three, but it may also be the speaker system we have in our cars. They aren't the best.
My LS and the lady's IS, have had zero issues, but then again, there was no Apple Carplay in either. I've yet to see if I connect via just Bluetooth if the sound quality will be any better or any worse compared to connected to Apple Carplay.
Ronb31 (01-11-20)
The issue is with the microphone when connected to Apple CarPlay via the USB cable. Using a cable is the only way to connect to CarPlay in the UX—at least for now. By design, BT is disconnected when CarPlay connects (Enform disconnects it).
Ronb31 (01-11-20)
Using Bluetooth in our UXs is not the issue. Neither are the speakers. BT works fine, as do the speakers.
Edit: apparently this is a common issue amount CarPlay users:
https://discussions.apple.com/thread/7590595
Possible work around from Rav 4 forum
I see, which sucks especially if we are using Waze or something on CarPlay to navigate, and we can't use BT separately for audio quality. We are essentially for the time being, forced to deal with this audio issue.
I saw a possible work around from a Rav 4 forum. Apparent for some people if you switch to speaker and then back to normal on the phone during the call the audio issue is resolved, at least for that call. You have to do this for every call though.
I haven’t had a chance to test it yet but I will report back if it works.
I just finished a phone call using Carplay and the audio quality was fine. I think you should plug your phone into the USB cable before starting the car.
Yesterday I plugged in the phone midway through my drive and audio quality was bad.
However, many times the phone conversation works flawlessly the first time but—on subsequent conversations—the microphone stops working (thus, the remote person can barely here you).
Were you able to test this in that fashion?
I've made 2 back to back calls on Carplay and the audio has been fine, I did notice that I have to max out the volume on the phone, doesn't matter if my iphone is connected via Carplay or BT. If it helps I'm in Canada, not sure how different a UX in Canada is compared to the US.
I had the same Problem Initially I thought tit was because I have carrier unlocked. So I bought another 11 max pro (tmobile only) it had older software that didn't work I upgraded it then it worked for 1 phone call.I plugged in my girlfrinds Phone same phone updated software one call. It works with my 7plus but I use that one as a dash cam only. The deler had the car for a week unplugged battery reset everything nothing happened.The phone work perfectly Lexus nx300h
All4Lexus (01-30-20)
I have been running the beta version of iOS 13.3.1 (on an iPhone 11 Max Pro) for a few weeks now and this issue has been resolved for me. I didn't want to broadcast this fact until the actual final release of 13.3.1.
This was fixed in Beta 2 back on 14-Jan.
Anyway, I'm finally happy with my Lexus UX and CarPlay integration!
theoryguy3
10-22-19 10:42 AM
