Non-Run Flat Winter Tire/wheel question
I recently purchased a 2019 UX Hybrid AWD luxury edition vehicle and looking at putting winter tires on the vehicle. I just wondered if there’s any specific size and or rim requirement for the Hybrid. As you know the UX Hybrid comes standard with 18” run flats.
Reason I ask is I have a nearly new set of 17 inch Bridgestone Blizzak tires mounted on Lexus 17” rims from my wife’s previous 2006 IS. I am not concerned with using non run flat winter tires as I previously ran in my previous BMW and we don’t venture too far from home in winter. The difference is of course that the UX is a hybrid and with brake regeneration I wonder if there is an issue using the older IS Rim as well as dropping an inch in tire/wheel size.
Appreciate any input.
The wheel diameter doesn't matter as much as the tire diameter. You'll want a taller sidewall tire to compensate for that inch. If the overall diameter is different, your speedometer/odometer will be off, and your ride and handling may be compromised. Not to mention, you probably don't want to be riding lower in the snow.
You have 225/50 R18s. So a 225/55 R17 tire would probably be closest in diameter.
Here's an online calculator https://tiresize.com/calculator/
Thanks for replies, I’m going to just buy same size as stock tires and rims.
Update: According to the Lexus Canada website and confirmation from dealer, see below:
TIRE SIZES
When your Lexus vehicle was designed, the engineers and product planners carefully selected a tire size, considering many factors, including performance, safety, and fuel efficiency. Lexus recommends that you select the original tire size when selecting winter, performance, or all-season replacement tires.Last edited by Jimmy3864; 10-29-20 at 01:14 AM. Reason: Updated info from Lexus Cansda
