I have these on my 911 and it is the Porsche logo of course but I don't get any interference from the door edge. The little projector part of yours looks mis-aligned somehow. Have you popped it out and tried to reseat it to see if that corrects the problem? The image shouldn't be cut off by the lower part of the door. I suggest you carefully pry it out and reseat it by setting the lower edge in first, then push the top edge in flush.
This is the link I used to buy the 911 lights https://biamaid.com/collections/car-...s-car-led-door . They have them for many makes of cars. I just went there to order some for my UX and noticed they have them for all Lexus models but they are divided into models that use the "A" version and models that use the "B" version. The UX uses the "B" version so now I'm wondering if JWW225 bought the correct version or was even offered a choice by whatever vendor he used.
I ended up buying two different kinds. The first was ‘kanouc” brand. They were Very dim, the wiring was not compatible, and part of the logo was blocked. So, I bought another set...‘Ghost’ shadow lights. They were Much brighter, they included wiring adapters and only a tiny bit of the logo was blocked. This is on a ‘20 UX250h.
