Replacing speakers
I am loving my new UX 250h so far, but the audio quality is pretty lacking to say the least. Has anybody replaced the OEM speakers with after market speakers? If so, do you have any recommendations as well as the estimated cost all in (parts and labor)? I don't need to be rattling windows with bass, but I'd like to get good low sounds as well as crisper highs. I haven't bought after market speakers in about 10 years so don't know where to begin.
If it's anything like the current IS, ES, and even CT that has 3" dash speakers (seems to be a common toyota/lexus trait) then you can buy some JBL Club3020s (3" speakers) and Red Wolf wire adapters and install them yourself 5 min per side. Great upgrade.
going further from there things get more complicated on newer/modern cars. particularly lexuses. but i'm not familiar with the UX system.
No. DO NOT assume. They are both different vehicles. You will need to pull the panels apart but I'm pretty sure you can find the info online.
CT is a dinosaur so probably not.
That's what I figured. Every website says something to the effect that "no information available if this speaker is compatible with your car". Some of them seem pretty universal, though. Is this something I should get done at a Lexus service center, or is the install easy enough that I can trust a local reputable car audio place?
I would take it to a reputable car audio place. Ones with great reviews and knows what they are talking about. I did a quick look up on lexus.jp since they do list speakers size. It looks like the dash speakers are 3", Front door is 7" or maybe 6x9", the rear doors are 6.5" and the rear subs is 6.5". This is for the 8-speaker premium audio. I think the 6 speakers would be the same minus the sub and center speaker. Lexus Japan doesn't offer the 6-speaker system and they do offer the ML system (no surprise.)
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/640x234/img_02_78e87970402eaec8b084dbf3598ba77428d67155.jpg)
source: https://lexus.jp/models/ux/features/sound_system/
BCGelandewagen (12-07-23)
Thanks for that info. I have the 6 speaker system, so I should have the ones shown in your diagram except C and E maybe? Either way, there is a nice audio installation place in town that serves all kinds of luxury vehicles, so I'll get some quotes from them.
There may be a grill in the center dash but there maybe no speakers.
I'm buying a powered subwoofer today and am going to attempt an install by myself. I know the general steps (disconnect negative, attach power, remove side floor/door panels to run cable to trunk, remove opposite side floor/door panels to run RCA to head unit, attach ground).
I am wondering if anybody has tips for how to most easily access the head unit to tap into the speaker wire, tips on removing the panels to run wire to trunk, and best place to attach ground. Thanks in advance.
There is no RCA behind the headunit. You will need to run a line converter. Some powered subwoofer will have a line tap input to tap into the factory speaker wires.
I would just tap into the rear speakers.
I keep forgetting the battery is in the trunk with the hybrid. That should make this process easier. I clearly don't know what I'm doing, so the easier, the better. The things I'm unsure of are how to access the speaker wire to tap into and how to ground.
The more I think of it, the more I want to let a professional do it. It doesn't seem that difficult conceptually, but actually performing the install may be outside my depth.
