I get this message on the lexus app for oil maintenance. The maintenance is up to date on drivers.lexus.com, it just had an oil change. There is no warning light in the car. Lexus Support wants to bring it into the dealership but they don't know what for. Does anybody know what needs to be reset? Lexus is stumped about this.
I believe there is one that you have to reset in the nav/8" display screen.
page 339 of manual:
■After changing the engine oil
The engine oil maintenance data should be
reset. Perform the following procedures:
1 Press or of the meter control
switches and select .
2 Press or of the meter control
switches, select “Vehicle Settings” and
then press “OK”.
3 Press or of the meter control
switches, select “Oil Maintenance” and
then press and hold “OK”.
4 Select “Yes” and press “OK”.
“Reset Complete” will be displayed when
the reset procedure has been completed.
then press “OK”.
So you're not going to look in the nav/display screen to reset your maintenance item. Ok. Fine.
Page 68 in the navigation manual. Reset maintenance item checklist. I also believe the info is sent to the data via the infotainment, not the gauge cluster. But take it to the dealership and prove me wrong.
I have seen that in the infotainment system on older Lexus vehicles I have owned. I am just posting my findings as I go, I have no interest in contests. It must be great to know everything.
From the same page in the Multimedia Manual, it indicates that the "Maintenance" settings is available on the 10" Lux trim. My sig shows I have the Premium trim (with base 7" display). I do not have the selection in my Vehicle setting in the Infotainment screeen.
