Installed Mirror Welcome Light, sequential blinker, DRL
SilverSFR (09-09-23)
10th Gear
10th Gear
Those are cool. I have the normal chinese sequential ones on my 7ES (same mirrors as UX, LS, LC etc installing is removing mirror glass, then separating the mirror assembly. not too hard but takes finesse since the pieces fit extremely intricately together. if you don't put it back together right it'll have gaps and stuff. so you have to pay close attn and look very closely all the way around.
I remember doing the puddle mod on the CT and it was done the same way. Good times.
10th Gear
the sequential blinker part has two wires and is basically plug and play since the lights come with the connectors. There is a third wire for the welcome light animation; for this, you need to remove the mirror assembly from the door itself and run that wire through the mirror and into the door and tap into a wire that’s in the door. Still pretty easy, but it’s not as easy as the sequential blinker only type.
Im trying to do this on the lc. would it be the same?Looked at a couple videos on youtube with the door panel off. Not 100% sure. it seems easy enough but also it seems not so easy. Any help?
