UX Models (2019-present)
Poor Fuel Economy (~30mpg)
Old 04-01-22, 08:11 AM
eggdropK
10th Gear
eggdropK's Avatar
Default Poor Fuel Economy (~30mpg)
Got my 2021 UX250h almost a year ago and my mileage has been sitting constant at around 30.7mpg regardless of season (I'm in NJ).
I don't drive like a maniac, but I'm thinking maybe my commute is keeping the MPGs down. I drive 18 miles each way from just north of the GW bridge to Long Island City, mostly bumper to bumper traffic. Tire pressure is normal, I use Shell 87 gas, and again, I don't think I've been heavy on the throttle. No big hills or anything like that either.
Is it my commute? Could there be something wrong with my car? Any suggestions are much appreciated.
Old 04-01-22, 08:24 AM
E46CT
E46CT's Avatar
Received 2,159 Likes on 1,622 Posts
it's likely a mixture of heavier than ideal pedal work and traffic. it's not totally out of the normal range for your type of driving but definitely on the bare minimum low side. See my tips here on how to get better fuel economy:
https://www.clublexus.com/forums/ct-...h-10-tips.html
eggdropK (04-01-22)
Old 04-01-22, 08:28 AM
eggdropK
10th Gear
eggdropK's Avatar
Thanks for the link/tips, I'll check it over. My last car was a 2013 Prius, so I thought I had a decent handle on how to "game" the system for better mileage, but it just doesn't seem to move the needle on my UX.
E46CT (04-01-22)
Old 04-02-22, 06:28 AM
rickeveru
rickeveru's Avatar
I find my UX does best in traffic since the electric motors kick in more often. Currently doing 38 mpg but improving as the weather gets better. During the coldest periods was doing 34.5 mpg.
Old 04-02-22, 07:51 AM
Funride
Funride's Avatar
I'm also getting about 38 mpg right now and when it gets warmer I get around 41mpg.
Old 04-02-22, 10:04 PM
brooklynux
10th Gear
brooklynux's Avatar
my experience is even weirder. i only use my 250h when i travel 90 miles each way to pick up my daughter(mostly highway). i use cruise control about 85-90% of the time. until about the first 5k miles, i got a best of 46.2 miles a gallon. i dont know if it was coincidence or not, but my buddy says he puts medium grade gas once in a while to clean out the injectors. i tried doing that just one time and all of a sudden, the economy started going lower. i dont have a heavy foot, but i have done 80's on the highway alot and even done over 100 just to test the car once. the worst i have seen was around 39.3 i believe. ive been conscience about the number so ive been trying to intentionally bring it back up and i finally got it to 40.2. i currently just went over 12k miles. im afraid if i didnt use cruise control or if my travel was more local driving, my fuel economy would be much worse. i know its rated for around 39-40 anyway, but i was getting 45-46 for a long stretch until i put medium grade gas. i hope i didnt ruin any sensors or anything because of that. anyone know whats going on possibly?
Old 04-04-22, 08:22 AM
LiBeRtAs
LiBeRtAs's Avatar
Glad to hear it’s not only me.
Driving normal not overly paying attention to the when the electric is running the car or not lucky to get 37 MPG.
Frustrating also that there is still no definitive answer which mode gives us the best mileage for normal driving, sport/Eco/normal?
i’ve read a couple times that sport gives you better mileage than the other two but I don’t know.
Old 04-07-22, 03:23 PM
ACHlLLES
8th Gear
ACHlLLES's Avatar
Nyc. Little above 40mpg. Eco mode all the time.
Little less than 2k driven on 2022 ux 250h f sport.
Old 05-16-22, 12:00 PM
Pdborst
1st Gear
Pdborst's Avatar
I consistently get 41.4 mpg and when on the highway, it will go up to 41.5 mpg. I live in Florida and use the air conditioner all the time, except in the winter on cooler days.
Old 05-16-22, 12:54 PM
LiBeRtAs
LiBeRtAs's Avatar
Cant get over 37 in town and then only if I drive everyone crazy behind me by accelerating as slowly as the car will go using adaptive cruise.
Using ECO mode, not sure if one of the others might actually be better.
Old 05-16-22, 01:02 PM
ACHlLLES
8th Gear
ACHlLLES's Avatar
been getting 41.8 with the weather warming up. Eco mode only.
Old 12-11-22, 11:01 AM
snzbrn
1st Gear
snzbrn's Avatar
I live in NJ, got a 2022 new ux250h in september. Barely used the car only for short trips. Twice I drove to work from edgewater to Morristown and got my tank empty last week and the odo was 324 miles which gives a 32.4 mpg. Very disappointing!
Old 12-11-22, 11:09 AM
LiBeRtAs
LiBeRtAs's Avatar
You have to pay very close attention to keeping it on the battery as much as possible, which is the green EV like under 35 mph. If you’re barely touching the accelerator, you should be able to stay on battery for a while it will make a big change in your mileage but you have to drive much slower so to speak.
Taking off from a stop, you have to very gradually increase your speed, etc.
Old 12-18-22, 06:51 AM
Ux200base
3rd Gear
Ux200base's Avatar
Default Mpg
I live in nj as well.. 2020 base ux.. non hybrid.. get about 42 mpg in the summer.. was doing 36-38 in the winter.. engine was running cold so I took it in.. the techs turned on all of the options in the climate control settings.. eco ac, etc.. back to doing 41-42 mpg and engine is running better again during the winter
I reset my mpg every time I fill the tank
Rarely take the car above 2k rpm, even when accelerating. On the highways, I try to stay consistent with speed.. 65mph is where I get food mpg.. at 70 it starts going down.. I can do 80 sometimes but it needs to be flat terrain.
I’ve driven your commute.. the stop and go is not good.. just makes me think you’re working the throttle too hard
Old 01-07-23, 02:49 PM
Adam200699
Adam200699's Avatar
2019 UX 250H with 110k miles. Average 41.2MPG. Daily commute from Bergen County NJ to Brooklyn.
Quick Reply: Poor Fuel Economy (~30mpg)
