CV Transmission woes
2nd gear
Other brands have horror stories about constant velocity transmissions.
I'm waiting for delivery of a 2023 UX. I reviewed the maintenance schedule and there is no mention of changing the transmission fluid prior past the120,000km mark.
Have you folks had any troubles with the Lexus eCV Transmission??
T.I.A. Brent
T.I.A. Brent
CVTs are not all the same
DAF launched the first CVT, Variomatic, in the late 1950s consisting of two pulleys of variable diameter connected by a belt. To give the lowest ratio the engine pulley is at its smallest diameter and the pulley driving the wheels at its largest. As speed increases the engine pulley gets bigger and the drive pulley smaller, increasing the ratio so the car speeds-up. It automatically adjusts for hills and harder acceleration. Similar systems have been used by Audi, Ford and Fiat.
The Toyota/Lexus hybrid CVT is nothing like belt CVTs. It consists of two electric motor-generators (MG1 and MG2) connected to a planetary gearbox. The compact package consists of only a few components. MG1 can start the engine and act as a generator to charge the hybrid battery. MG2 can act as a drive motor on its own or with the engine and also a generator for regenerative braking. The system allows electric-only drive by decoupling the engine without the need for a clutch.
While traditional and dual-clutch automatics are more popular, CVTs are particularly smooth around town. CVTs are generally extremely dependable and return impressive fuel economy. They provide instant power when you wish to pull away, although not everyone likes the noise they make under heavy acceleration.
Lexus and Toyota regularly top car manufacturer reliability tables.
There are a few videos on YouTube explaining the Toyota/Lexux CVT system, eg
Hope this helps answer your concerns.
Yep. Tired of people improperly conflating CVTs with Toyota's hybrid "eCVT" but I blame that on Toyota marketing. The two are nothing alike. the "eCVT" or more properly, the Transaxle, is a non-issue in Toyota hybrids. Think of it more like a differential box. Put simply, Toyota hybrids are actually the simpler, most reliable, longest lasting, and cheapest to maintain version of ICE powertrains this world will ever see, especially now that we are transitioning to ICE.
There's a guy on youtube a Lexus tech that shows you how to change tranny fluid. It's easy, going to do it at around 70 k km for me.
https://www.youtube.com/@Viktor_G/videos
