Pix requested: 255/35 on 20x10
I currently have Rear: 275/30-20 on 10, but need to replace tires pretty soon. Does anyone have pictures of 255/35? Some reason 275 is so much more expensive than 255 plus I will have more fender clearance with 255.
Do you guys recommend the 255 set up?
Thanks!!!!
Thanks!!!!
i liked having 255 35 on a 10" wheel.
look at my pics here www.putfile.com/19psi then go to the section titled "lexus stuff" .
The 255/35/20 is a .5" taller than the 275/30/20. Since the 275/30/20 is already over spec by a full inch, this might create some problems. I think a 255/30/20 will work better and is not an overly agressive stretch.
I have a Falken 452 265/30 on a 10.5, and it hasn't caused me any trouble at all.
Thanks guys!
Your help is greatly appreciated.
V8_Aristo - Are you on air suspensions? holly xxxx, your car is low. I can't clear hills of downtown Seattle with that height. Very nice ride.
man. i think maybe you should lower your lex some...it looks sorta jacked up like a 4x4... i mean come on if there's a breeze or strong gust of wind there's still a possibility a particle of dirt or a blade of grass might be able to roll underneath.
Damn side skirts, why do they have to be in the way
