Air suspension questions?
What is the views of using stainless steel hoses in the tire well section for extra protection from punctures etc.??? Where have you guys gotten them fabricated/made???
I have mine on the inside... no problems. As for braided hose, it'll get pretty expensive. I'm using or rather am in the process of switching to hydraulic hoses. Suppose to be much more durable and much cheaper! They are rated at like a million psi! so that seams pretty safe for me!
I understand about about active lines like Fuel, Oil and brakes.... but why not Air??? I've seen it done many times... Why don't you recommend it???
up to u tho..its your car. We all have our level of 'acceptable' car modifications
as far as the stainless lines for the trunk well: uh, use grommets
- Drill the well with a step bit
- prime the exposed edges
- buy a grommet kit or jus find the right size based on the markings on tha step bit.
- silicone the primed holes
- pop in grommet
- run lines
