Air management??
talk to jim bigford (if hes still there) over at easystreet. he use to be a member on my other car forum and is very helpful. i used the easystreet kit on my old car for 3 years. no self leveling here, just went by the psi in the gauges.
...not looking for self leveling..the easy street digital setup has this built in... im more interested to know if anyones got info on an add-on front & rear HEIGHT sensor kit for the easy street digital setup... or even a stand alone height sensor kit that i could use in conjunction with the easy street... i live in ny.. whats 95/95psi up front and 75/75psi rear one morning when its cold out isnt the same 95/95/75/75psi drop/raise in the afternoon when its warm... and that few psi is the difference between having the perfect drop, and your tire ripping your fender off when you go around a turn... whats more annoying is that based on how much you raise or lower your suspension to either max dump or max raise.. the 95 psi after you've been dumped isnt the same 95 psi after lowering it back down from a full up position.. dont ask me why but thats just how it is... and that is the biggest pain in the *** when you're driving and need to raise the car up quick, then have no clue exactly how far back down you lowered it without pulling over and checking all four corners again visually.. height sensors are a MUST if you do a lot of height adjusting on the road and like to ride with a stance low enough to ALMOST wreck all your ****. right now without height sensors, the only way i can tell when ive dropped back down "too low" is tire rubbing noise, basically when its almost already too late and im about to trash a fender...
baby jesus, please gift me with height sensors that like my easy street digital setup or can work on their own, so i dont have to trade it ALL in for something that already has them included!
sent ya a PM with a lil checklist of stuff to try before opting for another setup.
~Em
